Question about Dell Dimension 3000 PC Desktop
When powering up, the CDROM light just blinks every second
After pressing the power button on my dimension 3000 the CD ROM light just blinks about once a second and there is a clicking sound but nothing else happens. No video feed or anyhting else apparent. Just replaced the power supply with no change. What is the cause?
  • richp32 May 16, 2010
    I should have added that I already tried disconnecting the CD drive. The CD stops clicking/blinking, but the PC still is not booting. Power Supply is running and motherboard has green LED lit. At this point I'm thinking it's either the motherboard or a crashed hard disk. Any suggestions to determine which?
  • 23 Answers
Troubleshoot the problem this way. If the clicking noise comes from the CDROM then disconnect the power and ribbon cable from the rear of the CDROM and attempt to boot your PC again. If you think there is a CDROM stuck in the drive (and due to settings that let CDs such as Windows install disks boot from the CD ROM), You can get the CD out with the PC off by getting a large paperclip, and after straigtrning out the wire, you will see a small hole in the front of the CDROM drive usually below the tray that comes out for you to put the CD in. Push the paperclip in firmly, and the tray will pop out, letting you get your CD out. Retry booting after the CD has been removed.
Posted on May 16, 2010
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Dell Dimension 8200 PC Desktop Cd rom not reading disk
optical drive troubleshooting is pretty straight forward, fist see if you can boot to the drive using a bootable CD like the Windows CD or your Dell Resource CD, use the F12 1 time boot menu test it.
Also see if the drive is detected by model in the BIOS (F2 at boot) if not seen, reseat both power and data cables, boot to BIOS F2, turn on CAP LOCK SCROLL LOCK, NUMLOCK, then press ALT+E then ALT+F then ALT+B, this resets bios defaults and forces hardware re-detection. If you have no floppy diskette drive, you'll need to turn that back off in the BIOS before the ALT+B
If all that is done and the drive isn't seen/cannot boot to with bootable media, swap the data cable with the HDD and try a different power connection.
If Drive still not connected, replaced the drive.
If drive is detected and IDd then try this
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jan 28, 2011 | Dell Dimension 8200 PC Desktop
Replace cd rom in a dell dimension 3000
Remove the front panel first. The CDROM should slide out from the front.
Dec 13, 2010 | Dell Dimension 3000 PC Desktop
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
I have a dell dimension 3000 desktop. I removed a cd rom drive and replaced it with a audigy sound blaster front panel drive. when I boot my PC it says primary drive not found, press F1 to continue, Press...
Your computer is configured to recognize specific devices in your computer. If you removed the CDROM drive, you need to tell your computer that it's gone, and that you're aware of it. That message is kind of like a "Hey, there's something missing from your computer... did you know about this?"
You should boot your computer up and get into the BIOS. When your computer turns on, you'll see a message in the corner that says something like "Press F2 for BIOS" or something like that. Get into the BIOS menu using this option. When you get into the BIOS, you'll need to find the sub-menu called "IDE Devices" or something referring to IDE drives. You should see two IDE channels, with two possible devices per channel. You should see the entry where your CDROM drive used to be - change this option to "Disabled" and then save your settings and reboot the computer. The message should go away. Good luck!
Mar 08, 2010 | Dell Dimension 3000 PC Desktop
Hi, I have two cd drives that originally came with the Dell dimensions 3000 PC home edition I own, I've had them for a while, but recently my cd drive has ceased to work, the computer doesnt acknowledge...
The best bet and I have had several customers bring systems in with this problem is you have to edit the registry file and get rid of the upper and lower registry values once you do this save and reboot the machine it is just like a new drive was installed worked on all of theres one however came back to me twice and it turned out it was a conflict with other installed hardware. Hope this helps If you simply go to google.com and type clear upper lower registry values and the name and model of you drive as above it usually gives you a step by step and happy computing. Check us out on the web @ http://www.davispcrepair.com or contact me personally @ kzthomas@davispcrepair.com
Jan 14, 2010 | Dell Dimension 3000 PC Desktop
Cd rom will not read any cd
I would replace the cdrom with a new one. For the cost of a new one and the frustrations that you are beginning to experience .. got for new
Dec 18, 2008 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
75 people viewed this question
Alun Cox
