Question about Mitsubishi WS-55859 55" Rear Projection Television
Wont turn on
I have a hdtv 1080 series, model WS55859, production 1/02, wont turn on green light flashes then shuts back down
  • 1 more comment
  • 1bear4u Apr 01, 2008
    still need help
    still need help
  • 1bear4u Apr 04, 2008
    have not had time...hopefully over the weekend i will.........i will reply ...ty
  • 149 Answers
Work around convergence check voltage to convergence IC's if is ok, I' had same problem. find out one of the ic's was shorted
Posted on Apr 01, 2008
I have an Hd 1080 series one day i was watching tv and the volume just went up on it's own i couldn't turn it down and eventually i turned it off> since it hasn't turned back on at all. if i unplug it...
Are you saying the power light blinks constantly and does not stop blinking?
The model you have indicated does not flash light three times on its own.
Confirm model number and I will try to help you--WS65315 is the correct model number?
The more you tell me the better I am able to help you.
SD TECH
Feb 16, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi ws-55859 reset light flashing won't reset
You have blown capacators in your DM board. Here is a video that I used that guides you step by step video instructions for repairing TV. Bought the capacators at Radio shack for appx. $2/each.
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Jun 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
Mistsubishi HDTV 1080 Model WS-65611
hey there! good thing you posdt back. i dunno what happend earlier but that wont stop us would it. haha
anyway right,
have you tried changing your remote? it may sound odd but your tv may be fine and the remote is causing your tv to be like that.
you should try changing the remote first ok! cause probably a diode is messing the wat your tv should work.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
My 2001Mitsubishi 1080 hd Won't come on
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
