Question about Magic Chef Kitchen Ranges
I smell gas when using a burner on the stove. What could be causing that?
  • 494 Answers
Is there a delay when lighting the burner? That would give you a smell. Or does it light quickly? Are all the holes in the burner lit? Is it a nice, even blue flame all around? Have you spilled food on the burner? Is it only the one burner that gives off the smell? You may need to clean it.
Posted on May 15, 2010
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Gas smell by back of stove and burner amana model arg7302ww had applicance repair guy that used "lighter" and said no leaks, $65, and still smell gas in both spots...enough to make me dizzy,...
Firstly, The guy who tested with a lighter needs reporting to the professional body that qualfies gas engineers (In the UK he would have to be "CORGI registered" I presume you have similar in the US). Had he found a substantial leak with his lighter he could have exposed you to a lethal explosion.
Here is a vers safe ameture way to see if you have a leak:
First: Vevtilate the room so there is no smell of gas, open all the windows and doors and let the air blow through. If there is any hint of a gas smell, just call out a gas emergency service.
It's unlikely taht your leak is that bad and if you are happy that lighting the stove is not going to cause an explosion, do the following:
  • Turn the gas off at the main
  • Immediately, go to the stove and light the smallest burner
  • Time the interval between lighting and the flame dying out for lack of gas
  • Turn the burner control to off
  • Turn the main back on
  • Light ALL the burners (It may take a moment) to ensure any air is evacuated from the system
  • Turn OFF all the burners
  • Return to the main and turn that off
  • Wait 30 minutes to an hour
  • Without turning the main back on, turn on the small burner and time the interval it ramains lit again.
  • Turn the control to OFF
The time it took the burner to go out immediately after turning off the gas and the time it took after your 30-60 minute wait SHOULD be the same.
If it took less time to go out after the wait period, it's because some gas leaked out somewhere.
If the time was the same you have no leak.
If this demonstrates you DO have a leak, my advice would be to call out the idiot who tested the stove the first time and go through the test with him. Then, demand a refund on pain of you reporting him for a health and safety violation if you don't get your money back. Now throw him out of the house.
Call out someone who is more competent (Shouldn't be difficult, a trained chimp would probably out perform this guy!)
You can test the new guy's work the same way before he leaves too!
There is NO WAY that a leak like this should force you into a replacement stove unless someone can demonstrate what the failing component is and that costs more to replace than a new stove.
Hope all the above helps. Please drop a comment on this thread to let me know how you got on, or if you need any further advice
Jul 22, 2011 | AGA Legacy 44" Electric Kitchen Range
When I use my gas range it smells like lighter fluid. Only when it is on, when off the odor goes away. It is a dual stove with electric oven and gas top. It started with one burner and now all 5 of them...
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Nov 14, 2009 | Kenmore Kitchen Ranges
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Apr 06, 2009 | Frigidaire FGF378AC Gas Kitchen Range
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Dec 14, 2008 | Garland H283 Gas Kitchen Range
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
111 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
