Question about McCulloch 14" Electric Chain Saw Mcc1514
What oil does it take
Need manual, I do not know type oil it takes
    President:
  • 2,220 Answers
You provide no model number so my answer is limited. Use "Bar and Chain" oil available at most home centers and hardware stores.
You can likely find an OM for your saw here: If the entire model does not work try just the numbers then choose from the list provided.
McCulloch International
http://www.mcculloch.biz/int/
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 15, 2010
Lost the owners manual and need to know what type of oil it takes.
any good 30 weight will do fine. If yuo run it a great deal like I do mine I put a little STP type of lube in with the oil to help it out there. Also change the oil about every 50 hours so you dont get oil break down
Best of luck
Tom
Also could you take a second to rate us, this lets us know if we are giving you a good product
Sep 11, 2011 | Porter Cable 5,500 Watt Portable Generator...
Just got one as a gift. Need to know scheduled maintenance. Type and amount on oil. Type oil filter, fuel filter. Lube points. Everything to take good care of the bike.
Since you got the bike as a gift I would go to a kawi dealer or online and get a full maintance manual as they are not expensive and come in very handy for many reasons.
Aug 16, 2011 | 2004 kawasaki VN 800 A Vulcan
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Do not have manual and need one. Do not know what type of oil it uses.
According to the manufacturer, "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." I will need the actual model number of your saw (it should be loacted on the saw it's self) to see if I can find the manual for you. I hope this helps so far...
May 27, 2009 | Remington Electric Chain Saw
Want to change the oil myself,don't know how
look in your owners manual or look up online what type of oil you acura takes. Go to the store buy a 5 quart bottle of the oil type. Also buy an oil filter for your car. Just ask the people at the store to look up what filter fits your car. Get under the car or jack it up a little and put it on jack stands and get under it. Locate the oil pan and at the rear of it there is a small drain plug which is a bolt. Loosen it and get ready because once you remove it the oil will come pouring out so have a pan under the car to catch it. Then locate the oil filter and twist it off, replace the filter with the new filter and hand tighten. You dont need to gorilla grip it just snug it. Then replace the drain plug. Now your ready to refill with new oil up top. Make sure you get the right oil type and also lookup how many quarts your car needs. It is easy it takes less than 15minutes
May 14, 2009 | 2003 Acura 3.2TL
Oil? Gas? Additives?
Small engines like to see SAE30 oil. This is assuming a 4 stroke engine of course (if you have an oil filler spout and dip stick you have a 4 stroke engine). Use regular unleaded gas, and personally I mix STA-BIL into ALL of that gas I use with my small engines. I have too many carburetors to take the chance of needing to rebuild them in the spring.
Manuals for MTD products are here: http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need model and serial numbers
Apr 27, 2009 | Mtd Heavy Machinery
Oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Apr 08, 2009 | Craftsman Garden
How much oil does my tacoma 3l turbo diesal take
the best type of oil for a diesel engine is mobil 1 , and it should be at least 10w40 if not 20w50, I'd call a dealer and ask about the weight. They can also tell you how much oil it will hold, or you can just add one quart at a time until you get it full on the dip stick, I'd say no more that 4-6 quarts total, but I do know that diesel's usually take alittle more that a standard gas engine.
Apr 07, 2009 | 1998 Toyota Tacoma
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
McCulloch 14" Electric Chain Saw Mcc1514 Logo
173 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
