Question about Kenmore 400 6942 Dryer
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
  • Kenmore Master
  • 494 Answers
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
Posted on May 15, 2010
2 Suggested Answers
hondo73162
  • 132 Answers
SOURCE: My Kenmore 400 series is taking too long to dry
Make sure the vent and tube are clear and not blocked in any way, if clear try washing off the lint screen with hot water, softener will clog the filter
and not allow proper air flow, water will bead up on screen if this is true
Posted on Oct 27, 2009
Testimonial: "Thanks for the quick response!"
It takes 50 min to dry a load of clothes in my 400 series electric dryer can you tell me the problem. I checked the exhaust it looks clear thanks.
It could be heating problem and best way is to check for continuity in heating element and sensors and thermostats and limiters and thermistors in the dryer
Nov 17, 2010 | Kenmore 400 6943 Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
No heat, will turn on and spin with cool air only. does not dry clothes.
Okay, let me try to solve this with three possible solutions:
EASY AND CHEAP: Check the hose, the lint filter and the vent for obstructions. If the air is not getting out then the safety switch in the dryer will tell the element not to heat up. Without this safety switch the dryer becomes a fire hazard (and that's a whole other FixYa problem!). Make sure the hose is not crimped or clogged and that the outside vent is opening properly.
HARDER AND MORE EXPENSIVE: The heating element may be burned out or have a loose connection. This is a little bit harder fix but can be done without consulting a repairperson. However, if you have little or no experience then don't try that at home.
EASY BUT MOST EXPENSIVE: Buy a new dryer. If you do, see if the company you buy it from will take a trade in. If not, call a small appliance repair shop and see if they would like to buy your machine to repair and resell. This might offset some of the cost of the new dryer.
Hope this helps. Good luck.
May 26, 2009 | Kenmore Dryers
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 400 6942 Dryer Logo
404 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
