Question about Panasonic Microwave Ovens
The microwave oven will only run for 15 seconds
The microwave oven will only run for about 15 seconds before switchhing off
  • Panasonic Master
  • 9,047 Answers
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 16, 2010
How do you change the power level and what are they called?
Not all microwaves have the option to change power output but if the do, Full Power, Half Power and Defrost. The Defrost setting provides half power for about 15 seconds and then pauses for about 30 seconds before giving another 15 seconds and carries on doing this until the timer ends. It can also be used for keeping food warm once cooked.
Google
Make model manual
Jan 17, 2016 | GE JVM1790 Convection / Microwave Oven
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
Panasonic microwave NNP295SF shuts off after 15 seconds
It is going to be one of three things, the magnetron, " heart of the microwave oven " the inverter board, " if 7 years or less" and finally the keypad control board. In order to break this down, it will require testing to narrow the field. But what ever choice is made, the parts and labour are going to be the big factor when it comes to cost.
Apr 18, 2012 | Panasonic 1.2cu ft Microwave- Black...
When start Microwave after a couple seconds it stops and asks you to set the clock again.
The magnetron on most all microwave ovens is tied to the microprocessor that drives the display and the input from the keypad.
Check you manual to see if it comes with a self-diagnostic (higher-end microwaves from Panasonic, LG and Jenn-Air come with them) and run it (normally kicked off by a keypad sequence).
If unplugging the microwave and plugging it back in after about 15-20 seconds doesn't correct the problem, then I'd get it serviced if under warranty. Microprocessor will need to be replaced most likely. If not covered under warranty then you're looking at out-of-pocket repair or replacement.
Jun 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Jan 31, 2010 | Panasonic NN-SN657SMicrowave Oven
Microwave turns off after 10-15 seconds.
Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
also.
for heating problem
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay
Nov 09, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
Microwave Ovens Logo
93 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
