Question about LG Dishwashers
Lg dishwasher gives error code ee changed computer board but didnt help
  • 8,197 Answers
Hello and welcome,
Display Condition EE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Posted on May 15, 2010
What does EE code on lg dryer mean
The EE error code stands for "EEprom Error" which means that the main control board EEprom program memory is defective.
Replace the main board.
Feb 19, 2015 | LG Washing Machines
I have an EE code displaying on the front
Thank you for your post, friend!
I understand that your Frigidaire dishwasher is showing a "EE" error code. However, it appears "EE" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside of your dishwasher on the right hand wall. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 03, 2014 | Frigidaire Dishwashers
Keep getting E! error message. How do I reset on board computer?
The E1 error code on LG dishwashers indicates a water leakage problem on the machine.
Typically the water seal on the washing/drain pump has deteriorated and allowed water into the pump motor which causes internal damage to the bearing and impeller. Damaged parts or pump needs replacing.
Jun 22, 2014 | LG Dishwashers
Thermostat? LG Dishwasher Model: LDS5811WW
Hello Anonymous...
You hit on the reason ($$$$) I come here to contribute... Times are hard, money is scares... and my darling inhabitants are hurting...
Sometimes I can help not throw away a nearly perfect
(and faithful) appliance ... The ULTIMATE in recycling...
((Good for all of us... "inhabitants" (EARTH will be fine)).
((If you have ever seen our home from space...
It's a really pretty place. I'm not so worried for the place...
But there's a CERTAIN magic with these inhabitants...
If we pull together... It will be quite REWARDING)).
So...Thank you for ASKING.
I have a FREE manuals site where I start to read your
owner's manual... Better still... The Manufacturer also
prints "SERVICE MANUALS"...
several are shown... (don't go there yet)
ManualsLib Makes it easy to find manuals online
So being a MORE is BETTER GUY... I chose the one
that occupies the most memory....
and ran through the index 'til we got to trouble codes...
We are starting where your (pretty clever) sweetums found his
CODE clues... and we are going to look backwards..
To find "Thermostat"... (Found "thermistor").
Even if I am WRONG... You will now remember the secret handshake...& always know of the "MAGIC" of errors codes..
(which begin on your FREE page 36...
Although there is another "thermistor" error...
It is an over heat condition.. but it all for the entire PCB (printed control board) to be replaced
LG Dishwasher Main Control Board 6871DD1006Q
Code looks like an EE
with the top bar missing from the first "E"
(making it an inverted "F" (an important difference)...
We are going with ""HE""
HE"(symptom: water is not being heated)
Code yields...
>> HEATER ERROR... (check/replace "thermistor")
LDS5811WW (et al): >> (click here))...
LG DF6810WW Service Manual Page 36
This enables us to search on-line parts houses,
(everybody sells pretty much the same parts... $$, Services & guaranteed fits are different ... (My personal experience SEARS folks a rude, pushy, abusive but make up for all that by their higher than average prices... (I used to be a KENMORE fan))...
SEARS says.. the code is "tE"...
and further states the control board must be replaced
Now I use appliancepartspros, partselect, repairclinic (etc.)...
Sites (with VIDEOS) that respond to an internet search on
"LDS5811WW + thermister"
No "THERMISTER" parts found
Search Over 2 1 Million Appliance Parts
Sadly... Henry (SEARS) says the "thermister" is an integrated part of the HEATER... further adding "the part may be returned if it does not fix your trouble $54.03...ish
(SEARS = guaranteed fit).
Dishwasher Heating Element Part Number 5301DD1001A Sears PartsDirect
http://www.searspartsdirect.com/part-number/5301DD1001A/0022/722.html?modelNumber=LDS5811WW&categoryName=Dishwasher&brandName=LG
I am going to direct your reading to SEARs...
How to Replace Dishwasher Electronic Control Board Repair Guide Help Sears... Pictorial job description:
But do compare prices... and Happy hunting
Carnac the Magnificent
Jul 25, 2017 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG DISHWASHER TE ERROR CODE
you have 1 of 3 problems...the water is to hot over 140 degrees..your thermister went open,,or you have a bad pc board,,(control) onthejob
Feb 04, 2009 | LG LDF6810ST Stainless Steel Built-in...
Error message
EE error code with the top of the E missing is due to a faulty Thermistor.
Dec 03, 2008 | LG WM-2277HW Front Load Washer
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
76 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
