Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
Error message: HD521-2W
I ran pc-doctor on my compaq presario, and when I ran a diagnostic for my hard drive,(Short Test), I received the error message HD521-2W. The program directed me to contact my administrator with this error message. I have tried several things to find out what this means, with no success. Please advise.
  • 4 more comments
  • Anonymous Apr 27, 2008
    I have the same exact problem
  • pmwilson May 30, 2008
    same problem
  • vinny boy Sep 23, 2008
    I too have a Compaq Presario and exactly the same thing keeps happening to me (4 times in less than 2 years), forcing me each time to do a destructive recovery which returns my PC to its delivery settings and forcing me to re-install all my data and post delivery software. It is a real pain and HP were NOT interested even when it was in warranty!
  • plcoon Nov 01, 2008
    same problem, how can i get force windows to start so i can recover a file. i get missing or corrupt: window\systems32\config\system
  • mitchy68 Mar 15, 2009
    Same problem here! The last post is right on what was said. Eventually you have to reinstall your os every time you try to start your comp. But what did help mine is dont defrag and dont update certain windows updates after you reinstall os or do destructive sys. recovery !
    By the way The non destructive sys. recovery & sys. restore wont do, you have to do the destructive sys. recovery.
    My product is Samsung SP1614C
    my error codes: HD535-4 & HDD535-S2
  • martinmaloney May 07, 2009
    HD521-2W FROM PC DOCTOR failed short self test.guess the undies are in a bunch , need to know how to pull out the hd521-2w / other wise no problems ,runs quiet ... well there are problems , but cannot relate them. you know how relatives can be.I SEE SO MANY HAVE THIS PROBLEM HD521-2W NOW.is there a virus or what ?
This error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Posted on Jul 27, 2008
Posted on Mar 15, 2009
Replaced my hard drive after knocking my laptop and receiving a DST short test fail error. Upon receiving the new hard drive all was working well until it started to slow down 2 weeks later. Now I've...
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Feb 14, 2013 | Computers & Internet
Error 301 hard
Compaq laptop has detected a SMART fault. You should backup your data and test the harddrive with the maufactures diagnostics like Seatools for Seagate. Run a short DST. Drive may pass. I would still replace it. Clone your current drive to the new one. The drive is probably on its way out.
Aug 20, 2012 | Compaq Presario CQ61-310US Laptop
I ran the short test for the ST350063 OAS SCSI Disk Device in PC Doctor hardware diagnostics test and it passed. I decided to run the long test right afterward and the Surface Scan test failed. The...
You could run it again, you probably have some bad sectors. The drive might be fine for years or it could die, very hard to tell. Hard drive failure is the number one problems on PC's next to spy-ware and virus's
What I would recommend either way, is back up important files and folder.
Dec 23, 2010 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
3,066 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
