I have a Mitsubishi CS32307 32 inch crt tv. Green light comes on for about 3 seconds and shuts off.
  • Patrick McAlexander May 18, 2010
    d961 shows a short in both directions. Mits cant help me with the part's value they just give me the part number and its no longer available.
  • 10,594 Answers
This kind of symptom appears when tv got problem in deflection section, specially in horizontal deflection section on main circuit board and another cause could be dry/ cold solder joints in circuit board.
Visual check of circuit board is necessary by qualified technician to get tv fixed. Local tv repair shop will help you to repair it.
Hope this info will help you.
Thanks.
Posted on May 16, 2010
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 29, 2012 | Mitsubishi VS-45609 TV
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
Tv will not come on. the green light on the front on the tv blinks, the blue screen come on and the tv shuts off. I've tried the reset procedure. I've unplugged the set for a while. Nothing works. The TV...
First the tv cannot be only 3 months old, (needs chassis rebuilt- send to mitsubishi they do it for around $300) and how did we go from DLP to adjusting screen levels and focus adjusment? PLEASE if you have limited knowledge you will be more helpful if you don't share it.Thanks
May 30, 2010 | Mitsubishi WD73727 73" HDTV
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
