Question about Car Audio & Video
Infinity car speaker
Why are there four wires on these instead of two. An amp?
  • Tygh Duval
    Tygh Duval May 11, 2010
    What are the model numbers of the speakers?
    Sergeant:
  • 300 Answers
It's very possible the speakers have dual voice coils, therefore, would have two "+" and two "-" connections. With the model numbers of the speakers, I can confirm that for you.
Posted on Mar 31, 2008
Speaker wiring diagram for a 08 dodge 2500 truck with 7 speaker infinity
Never have found good wiring diagrams for stereo's. Bought them and color codes didn't match. I have mitchell and alldata at work, they don't match. I wire them in with a volt/ohm meter. I find B+, Then hook ignition the the heater control wire. Ohm out the speakers. Thing is, you have infinity. You'll have to find the amp and cut the speaker wires and patch them there also, first. Just a note.. All speaker wires are twisted/paired wires. Cut the tape back 4 to 6 inches to find them. Another note. The speaker wires from the stereo to the amp will be a set of colors. From the amp to the speakers will be different colors.
Nov 01, 2016 | Dodge Cars & Trucks
I have a four channel rockfor fosgate amp and I need to know hows the best way to connect Infinity Reference 1252w Car Subwoofers
Rockford fosgate usually work best with 2 ohm speakers. Depending on the resistance of your speakers, will then give you best connection. Check the resistance for the subwoofers. If the subwoofers are two ohm then connect them directly right and left. But if they are 4 ohm connect them parrallel (positive to postive, negative to negative and bridge the amp.) Good Luck, please rate.
May 26, 2010 | Infinity Reference 1252W Subwoofer - 12"...
I have a 2002 Chevrolet Camaro with the Monsoon stereo system, The front speakers take four wires. The Infinity Kappa 62.7i were the perfect speaker, but they stopped making them. I do not want to put...
one of those wires on your speakers is the common ground for both sets of wires in your camaro, Just take the negative wire from both sets of wires and run it to the single wire on your new speakers. The other 2 are positive from each wire. good luck
May 24, 2010 | Infinity KAPPA 62.9I Car Component System
How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
May 21, 2010 | Infinity Reference 1600a Car Audio...
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Volume low on all four speakers, some static (amp or head unit problem)
I would check the amp first, especially if you have very low sound on the speakers. Before amps were made, bad output transistors would create the same effect.
Apr 13, 2009 | 1997 Chrysler Sebring
Jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Sep 04, 2008 | Car Audio & Video
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
