Question about Poulan Pro " Pro" Self Propelled Mower
The pull gets stuck halfway up. Feels like it's tangled inside where the cord retracts. Is that possible?
  • 903 Answers
It's possible it could be tangled, but more than likely you just need to oil the drive shaft. Dirt and debris and grass can get caught up in there and keep the shaft from spinning and the blade from turning.
If you turn your mower over and apply some oil or WD-40 on the shaft where it disappears into the body of the mower, then spin the blade (carefully!) and shoot some more oil in, the blade should begin to turn easier, and that should take care of your problem.
Posted on Aug 28, 2010
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Pull cord will not retract when assembled. When I took the head apart it works fine.
The question then becomes 'What's stopping the cord from retracting?'
Friction somewhere along the travel of the cord or the winding mechanism is causing this. Find the rubbing point and correct the alignment. Be sure the spring is correctly wound first before re - assembly. There must be spring tension on the winder mechanism to function correctly.
Other than that, check to see if the cord is tangling on itself and preventing the rewind from working.
Jul 17, 2015 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
I opened the vacuum,i checked the cord and it is in the correct form,not tangle etc..still doesn't work after pluging it the wall out let..help
Possibly a broken wire. It is common for the flexible cable to break at the 3 pin plug end from constantly pulling the cord / plug out of the socket or if its a retractible cord, they get broken where the cord enters the machine rewinder. this happens when the cord is pulled out to its maximum length all the time and eventually cuts through the cord. I would try a new 3 pin plug first.
Apr 13, 2015 | Vacuums
Power cord wont fully pull out or retract?
There is probably dust causing the roller to get stuck. Try spraying some WD-40 just a small spray inside the hole the cord retracts into and see if that helps.
Feb 20, 2015 | Vacuums
Retractable cord stuck
I wonder if there is a tangle in the cord. It could have also come off the wheel inside. Open the vacuum to see if you can untangle the wire and put it back on the wheel.
Nov 29, 2013 | Hoover Vacuums
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
Our tractable cord is half-way stuck and will not retract and its all tangled inside and you cant pull it to use it
The only thing you can do is you must open it by removing the screws and take it apart your self, once open it should be apparent what to do, or take it in for the repair.
Jul 04, 2011 | Hoover U5753-900 WindTunnel Bagless...
Pull cord is stuck
This happens all the time. To fix it is not to bad. You have to take off housing around where then pull cord is, then when you get to the pull cord pulley, sometimes you can just untangle where cord is. The pull cord is in like a spring housing , this is what retracts it. It is all spring designed to pull and retracted. You will notice that when you take off pulley, there our little tabs that are bent in, that is designed to hold rope pulley in. There is a spring set up behind that. If rope is just tangled or crisscrossed then can carefully untangle and put back together . If not take that whole piece in and they can replace spring that has worn out or jammed. Hope this helps, I had it happen to me on a edger , was not to bad of a home project. Thanks, mike from fixya
Jun 13, 2011 | Garden
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro " Pro" Self Propelled Mower Logo
119 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
