Question about HP Computers & Internet
I have a pavillion d5000t and logitec x530 speakers and cannot seem to find the right combination to plug in the speakers - speakers have a black, a green, and an orange plug in and the computer has a black, a gray, a green, a orange and a pink port. I have tired several different combinations. They do not work when I use the color coordination method. I have window 7 upgrade. I had this same problem when I first set up the computer. Had to unplug them while on the phone with HP tech support and don't remember which went where when they were working.
  • HP Master
  • 5,125 Answers
It should go black to black, green to green, and orange to orange (the color coordinated pattern). I suspect your problem may be in the audio driver or a bad wire or bad sound card/ports.
First try re-configuring your audio (like you did when the computer was new):
If you have an audio card, start the software for that. Start > All Programs > Creative > Creative Sound Console. If you end up in Entertainment mode. Click on the Speakers tab and Autoconfigure the speakers.
If you have the on-board audio, see the Realtek audio in the Device Manager. Start > Control Panel > Hardware and Sound > Realtek HD Audio Manager. Click on the Speaker Configuration tab and choose your audio set-up.
Check if the Device Manager has a red x or yellow exclamation point for the audio. Control Panel > Hardware and Sound > Device Manager. Try updating the driver. (In Windows 7, this works best if Windows Updates is set to automatically install drivers as well as other updates. Look in Windows Updates, the driver may be waiting to be installed.) Then try reconfiguring again after a reboot.
Also check if the speakers are getting power. Note: the configuration step above won't work if the speakers aren't powered and plugged in. Try them on another computer if you can.
I hope this helps.
Posted on May 15, 2010
Which color wires go to the pin on a d-sub connector for a logitect x530 speaker system
Connect the d-sub connector plug (the VGA cable,probably black colored) into the subwoofer.
Oct 12, 2011 | Logitech X-530 Computer Speakers
My logitech x530 speakers are not playing
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 28, 2011 | Logitech X530 5 Speakers
How can i plug my x530 speakers into my laptop which only has the mic and headphone inputs. whilst the speakers have the green, orange and black cords? thanks.
U can buy a connector cable to connect th audio device to your laptop. There are diff types of connector cables...
Eg:
U can simple connect the color codes to it and enjoy the music..
Good Day
Dec 15, 2010 | Logitech X-530 Computer Speakers
FRONT RIGHT SPEAKER do not turn on, no power
Sounds like the amplifier has gotten a surge of power and gotten fried. You will need to replace your system as there are no user servicable parts inside the unit. You can also try seeing if there is a fuse on the main speaker prior to getting a new one. Also check all connections to make sure your getting power too
Aug 06, 2009 | Logitech X-530 Computer Speakers
Logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
Oct 05, 2008 | Logitech X-530 Computer Speakers
X-530 Not working!!
Ensure that your sound card setup/diagnostic software can correctly recognise your speakers. You will need to know what sound card is in your PC. Be carefull with PCs that have sound cards built onto the mother board and that also have a seperate sound card. Ensure the sound card you want is the one you have plugged the speakers into and ensure you have disabled the other sound card and its software.
May 02, 2008 | Logitech X-530 Computer Speakers
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
