Question about Maytag Dryers
I have a Neptune Gas Dryer that stopped heating....but still goes, is it worth fixing?
  • 494 Answers
If it's only a few years old, it would be much cheaper to fix than to replace the unit. Chances are it only needs a new igniter and you'll be saving lots of hard earned dough fixing it. Easy things to check on your own include: Clean your filter. Clean out the vent behind the dryer. Clean out the vent outside at the vent cap. Turn on the dryer and see if the igniter glows orange. If it doesn't, it may just be broken and need replaced. Good luck.
Posted on May 15, 2010
Describe your Neptune MDG9700A Gas Dryer Problem igniter clicks a couple of times then stops, burner does not light. had code of 02
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Maytag Neptune MDG9700A Gas Dryer
Stopped heating?
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Stopped Heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Stopped heating up. Gas is on and everything works but the heat doesn't come on.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Why my maytag Neptune gas dryer stopped heating up?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Neptune all of a sudden has stopped blowing hot air , I have had all the setting correct.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MDG5500AW Gas Dryer: gas dryer will not heat...
heatman101
May 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stopped heating
heatman101
ttyyt
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
