Question about DISH Network EZ Remote Remote Control
Have to manually turn on tv when turning on digital converter box
We have a box that convers an older Sharp tv to digital. The remote says "dish Network" 1.5 NDB #160949. Can anyone tell me where to view an instruction manual that tells me how to turn on the box and the tv at the same time with the same remote? Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Posted on Jan 18, 2011
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
How to turn off subtitles on a hitachi tv
This may depend on the signal source of the TV. If you are watching OTA TV (or your TV is interpreting the CC from the cable or satellite signal), then use the CC button on the remote. Alternatively, depending on your exact model Hitachi TV, try using the menu to find a Tools or Options sub-menu and then turn off the CC from there. This could be under a different menu item. If you add a comment with your model number, I'll be glad to give the exact menu steps.
If you have a set-top box (cable, satellite, digital-to-analog converter box, DVD recorder), the captions may be turned on at this source. Then you will need to disable the captions from that box. With a converter box, press the CC button on the converter's remote or enter the menus for that box.
With a Dish TV set-top box, press Menu on the Dish remote, go to Properties (item 9). Click Select and then go down to Closed Caption (item 6), and press Select again. The first item in this sub-menu lets you turn on and off the captions. Press the left button and then up or down arrow followed by Select to change the setting. For other sources, check the instructions for that device or add a comment with the specific source for a solution for that device.
I hope this helps.
(the Dish CC procedure is for the box I have to deal with; I can't guarantee that updates/model changes have not changed the procedure.)
Jul 15, 2012 | Televison & Video
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
DISH remote will not work for the first 10 minutes when the TV is turned on; so, I have to watch the channel I was watching before I turned the TV off. It seems to work fine after the initial 10 minutes.
Is the TV new? Is it a HD TV? If it is Either a 9Samsung LN(R/S)## Series , Sony Bravia/XBR# Series ,Sharp Aquos (New Models) , or Phillips ##PFL Series than the issue your haveing is what we call IR Remote Response Lost. its a light that cuts on and off that makes any IR remo not work some period of time. You have too call the TV manufactuer or use the manual for assistance. If you need details on how too fix it let me know!!!
Nov 01, 2009 | DISH Network IR Remote Control
Remote does not work for first 5mins when tv is turned on
There are a lot of possible culprits that may be causing this i.e . light source between TV and remote usage location, sunlight infiltrating into the pathway etc. However the easiest solution may be to have a technician come out and troubleshoot the issue. You may opt for a IR/UHF converter which is easy to connect and allows you more versatility with the remote. Thanks for using Fix Ya.
Sep 24, 2009 | DISH Network IR Remote Control
Need Universal code for RCA remote with Apex DT250 Digital Conver
Use cbl/sat button. Your remote might use more or less than 4 digits. Use 749 or 00749. It'll probably work. It worked for me.
Jul 30, 2009 | Televison & Video
How to turn on TV with insignia digital converter remote
You'll need to program your remote control for your TV. To do this, ensure that your TV brand is one that can be controlled by the remote (a listing is in the owner's manual). Turn on your TV, then press and hold the TV Power button on the remote and press the Channel (CH) ^ or v buttons one or more times until the TV turns off. I hope this helps.
Jul 28, 2009 | Insignia Digital-to-Analog Converter for...
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
DISH Network EZ Remote Remote Control Logo
359 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
