Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
FGX831CSI Stakable FGX831CSI Washer smoking on spin cycle, won't spin, do I have to remove dyer panels to remove washer panels to check to see what I can find? Sounds like transmission problems.
  • 2 more comments
  • DEGUAIR Mar 30, 2008
    NEED HELP!!
    tub won't turn both ways.t
  • lavcheech Dec 26, 2008
    My washer will wash but is not spinning and draining - FGX831CSI Model.
    Now I got a load of clothes with water inside.
    Please help me out. Thank you - I appreciate it.
    Anthony
  • robert samples May 11, 2010
    first open the lid and see if the tub will spin both ways and how old is the unit
    President:
  • 1,314 Answers
Ok possiable not tranny problem no just take two screws out of the bottom panel of washer and pull down on panel proably a burned belt or broken spring on belt idler pully
Posted on Mar 30, 2008
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Low rumbling noise and washer won't spin
Remove access panel and check to see if the belt is on.
Nov 12, 2012 | LG WM-2277HW Front Load Washer
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Smoking washer
once you get the front panel off check the drain pump while your in there right now get a flashlight and look very closely at the holes in the tub for something like a nail or screwhead or something small enough to have slipped down in one of the holes of the inner tub and be jamming it now when you check the drin pump be warned there will be water still in the pump and tub so put down a bunch of towels
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
253 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
