Question about Grilling
I need instruction on how to put together model 8300 proseries Brinkman
  • 494 Answers
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
Posted on May 15, 2010
Looking for a brinkmann 810-3200G replacement burner
Unfortunately, your model grill has been discontinued by Brinkman. The burner you need, Part # 19810-3200-G is no longer available and there is no substitution.. Neither from Brinkman or other grill part sources. In fact, the only 2 parts available from Brinkman for you grill are an ignitor button & cooking grates.
I'm sorry, I wish I had better news for you. Thanks for choosing FixYa.
Jul 27, 2011 | Brinkmann Grill King Deluxe 810 3200-0
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
How do you take the support out for the burners? Mine are rusted and need to try to take out to put new one in. this is a brinkman 2500 pro series
If the screw heads are extremely rusty, you can either try letting the screws soak a bit, after applying penetrating oil. Or cut the heads off with a hack saw or hand held, hack saw blade. Then lift the support out of the way. A bit of the screws will still be sticking up and you can use a pair of vise grip piles to carefully unscrew them. If the remaining shafts of the screws look extremely rusty, apply penetrating oil to them, wait ten minutes and carefully back them out.
if all else fails, you will have to drill out the screws. But, you will need to use a larger diameter screw when installing the new burner support.
Good luck and I hope this helped you solve the problem. Please don't forget to rate my response to you. Thanks!
Apr 16, 2011 | Brinkmann ProSeries 810-6330-W Grill
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
No user instructions for brinkman smoker
May I get the make and model # to help you more
Jul 03, 2009 | Brinkmann Smoke 'n Grill Double-Grill...
Instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Jun 27, 2009 | Brinkmann Stainless Steel All-In-One Gas...
GE PROSERIES SPEAKER PHONE MODEL GE 2-9438B
I found the mini-reference book to my GE ProSeries 2-9436/2-9438 under the number log on my phone. I scanned the pages into a PDF file. I'll be happy to send you a copy of the PDF file.
Aug 15, 2008 | GE 2-9438C Corded Phone
Brinkman SmokenGrill instructions on pdf
For all users who needed this manual, if you still don't have it, here is the link:
http://www.brinkmann.net/Docs/Pdf/810-5301-C.pdf
If this solves your problem PLEASE rate as fixed. If you already had the manual then please don't rate at all. Thanks.
Jeff
Jun 07, 2008 | Brinkmann Smoke 'n Grill Double-Grill...
Grilling Logo
168 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
