Question about Drills
Hole in drywall. need a cheap fix - Drills
  • 2,100 Answers
How big is the hole? A cheap fix is this stuff called fluff, it is lightweight spackling compound, comes in a little tub, will dry hard as a rock, and stay put. You will need a knife big enough for the job, not a little putty knife but a 6 inch dry wall, depending on the size of the hole. A little mesh tape might help a big hole. Hope this helps.
Posted on May 15, 2010
How to fix 1 inch holes in drywall
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Apr 06, 2016 | Drywall
Tip
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
on Jan 23, 2014 | Drywall
Tip
Minor Drywall Repairs
<span>It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.<br /><br />For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.<br /><br />The easiest way to repair a larger hole in wall board:<br />1. Cut a piece of new wall board larger than the hole you want to repair.<br />2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.<br />3. Using a drywall saw, cut out the outline of the patch on the wall.<br />4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".<br />5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.<br />5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.<br />5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.<br />6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.<br />7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.<br />8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.<br />9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.<br />Hope that this was helpful.<br />Best regards, --W/D--</span>
on Feb 03, 2011 | Plumbing
My 2012 wall air condioner is leaking. How do I fix this and repair the drywall?
It sounds like the drain line is plugged where it goes outdoors, so water is backing up inside the unit until it spills over indoors. Clear the drain line.
You may need to cut a section out of the drywall where it's been damaged, then get a matching piece of new drywall to replace it. If you can cut down the centers of two studs, all the better - then you can screw the new patch directly to the studs on both sides. If not... at least leave yourself a couple of inches of drywall to stitch to - you can do that by screwing small pieces of plywood to the existing drywall, overlapping the hole. Then you can screw the new drywall patch to the plywood.
Next is your adventure in taping & mudding & sanding the drywall to finish the patch. Last, paint it to match the rest of the wall... or repaint all of that wall, including the patch. No need to paint adjacent walls, if your color matching is pretty close.
Jul 26, 2014 | Samsung MH052FNCA 18000 BTU High Wall 410A...
How do I repair a large hole in my drywalled wall in my living room that is right beside the door frame?
If you live near a Home Depot or Lowes they sell partial sheets of drywall. Cut a square slightly larger than the damaged area from the new drywall. Trace this around the damaged area and then cut out the damaged area with a key hole saw or sawzaw or if you don't have those just your utility knife. You can probably buy all the tools and materials for a lot less than hiring someone. Since you said the hole is next to a door you shouldn't have to worry about electrical wires, but just in case, take a flashlight and look into the hole before you cut to make sure. Now you should have a hole the size and shape of the new piece you cut. The area against the door is against studs and you'll have to just keep cutting with your knife until you get through to the wood. Now, on the other side of the hole across from the door take a piece of scrap wood and put it inside the hole and press it against the inside of the wall so half the scrap wood is behind the wall and the other half is exposed in the hole. While you're holding the scrap wood you'll need to screw 1 1/4" drywall screws through the existing drywall and into the scrap wood. The scrap wood should now be tight against the back of the drywall and partially exposed to resemble the stud on the other side by the door jamb. Now you have backing for your patch. Place the patch you cut earlier in the hole and screw it in place. A screw gun or drill with #2 philips head screw tip will make this job easier. The screws should be counter sunk just slightly so the heads don't rip the paper. If you do rip the paper you'll need to put in another screw near that one or else you'll have problems later, especially near a door. Now finish the hole with joint compound. You can buy this at most hardware stores in a one gallon bucket. You'll need a role of drywall tape as well. I recommend the fiberglass mesh tape for ease. Also you'll need a taping 6" taping knife and a tray.
Fill the joint compound tray half way and mix it around with your knife until smooth. Take the fiberglass tape and stick it to the wall around the patch to cover where you cut. Spread a thick layer of joint compound over the fiberglass tape and then gently wipe it all off with one or two strokes. Repeat this until all the tape is covered with a thin layer of "mud" (joint compound). Make sure all the screw holes get filled too. Let this dry for several hours, maybe overnight. Put the excess mud back in the bucket and clean your tools. When the first coat is dry take your 6" taping knife and scrape away any blobs of mud that you left behind from the first coat and then apply a second coat. You may need a third coat. Sand the joint compound until smooth tapering the edges to the paper. Again, be careful not to sand the paper too much, you don't want to go through. If you have smooth walls, you're in luck, now just paint. If you have textured walls then you have more work. you can get spray texture in an aerosol can at the hardware store. Read the instructions on the can and practice on the left over drywall from your patch. Note: you'll never make a perfect match with this aerosol texture but you can get it close. The only way to get a perfect match is to use a compressor and and special spray gun for joint compound and it takes some practice. You can rent these things in most towns if you're very particular. Good luck
Aug 09, 2013 | Tools & Hardware - Others
Tip
Drywall Tip!!!!!!Rrepair ti yourself
If for some reason A hole becomes appearent and a Man or women have to fix it.......... Mud around The hole with a light coat of drywall compound and then put the screem mesh drywall tape in plece.Let it set.Remember to cover the hole diamenter with tape and mud in all edges to be uniform. Let set till dry and white and smoothly apply another coat without leaving streaks of mud. Last coat..........put a little water in a ice-cream tub or something of this nature and add drywall compound to make something to the nature of a pancake batter and feather out the edgesof your best mud job that you ever did, let dry and lightly wash down with sand-paper and get ultiment resaults every time..Prime and paint.
on Aug 21, 2010 | Audio Players & Recorders
Walls too damaged to paint
Use drywall mudd. Its cheap, easy to apply and sands to a smooth surface.
https://www.thisoldhouse.com/how-to/how-to-finish-drywall
Apr 20, 2017 | Microwave Ovens
Fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
Feb 03, 2011 | Washing Machines
Drywall hole
cut the drywall, square,from the center of one stud to the center of the next stud and remove. Now cut a new piece to fit and nail or screw in place. Tape the joints with mesh tape and coat with drywall mud. Use a ten inch broad knife for this. One coat of mud and let dry. Next day another coat of mud pull it tight this time and let dry Sand and apply desired texture
Jun 18, 2010 | Saws
Hole in my wall
If the hole is less than an inch diameter: use a hammer to tap the hole edge to bevel around the entire hole. Using the screen type drywall seam tape, cut the tape slightly smaller than the beveled area. Apply drywall spackle or compound to the hole, flush with the surrounding surface, then gently press in the tape evenly. Let it dry (6-8 hours), then lightly sand or wipe over with a damp sponge. Now apply a final coat of compound flush to the wall surface. Touch up with paint.
If large, say 6" or more: get a friend that does drywall to do the repair unless you have woodworking experience! Short of that respond to this FixYa and I can walk you through it.
Feb 27, 2009 | ALi Do It Best Precut Drywall Sandpaper...
Drills Logo
60 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
