Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Need video or large diagram instructions for what to put together
Bought Shark S3501 Steam pocket mop to clean near new hardwood floors. Need diagram instructions for what to put together to use Shark steam pocket mop, including which pocket or cover for hardwood. Pamphlet that comes with it is long and small print and diagrams not good enough. Do you know of a video that shows how to do this?
Before using steam mop, vacuum up or run dust mop over floors to release all loose dust and debris. Notice if anything like tar or stuck on food that sticks up a bit from floor and remove. (The stea, mop can clean surface drips but not something that you can feel sticks up by running finger over it; remove from floor first).
Attach the rectangular attachment to the bottom of the steam mop as seen in diagram showing it all put together; this is the main pic for the steam mop.
Then choose the purple pocket, (the shaggy latex looking one with the 'little fingers or knobs) and attach to the rectangular attachment. You may have to open the velcro along the top first, but then slide it up from bottom toward where the rest of the mop is, as if putting a pillow on a pillow case. Tug a bit at the top so you can fasten the velcro tabs together over the top of the attachment.
Unscrew knob that is on the front at about waist high on the mop. Fill the cup provided with water to the fill mark. Pour water into the water holder and replace knob and turn just a bit until tight.
Plug the cord into an electric outlet.
Place mop in area to be cleaned.
Wait about 1 minute and then start pushing the mop on your floors. You will need to use a scrubbing motion back and forth as it is this motion that releases the steam. The mop is not self propelled; it takes some muscle to scrub/mop the floors with steam coming out.
Mop one small area at a time and go back over it to clean that area. i.e. in a relatively small room, clean two boards at a time from one end to the other; in a larger room or hallway, clean about a 3-4 foot section at a time.
If you have a fairly large area or more than 2 small-medium rooms, you may have to refill with water, but not usually. If you do need to refill, be sure to unplug mop first, then repeat from start of mopping.
Remember as you are cleaning that you can flip the mop foot over and use the other side of the pocket. For example, after cleaning a 10'x10' surface.
This should work for you. I know I had to look up video just to see what they were cleaning with on each surface although no directions. (The one below does not show the purple pocket in use for wood floors but that is the one you use; you could probably use a white quilted one on lamintate floors so presume that's what they were doing here and that was not hardwood):
http://www.sharkclean.com/steampocket/steampocketoffer.shtml?pcrid=5705341571&sid=s14061394
Hope this helps
Posted on Oct 03, 2010
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ui
Posted on Sep 30, 2010
It heats water inside the machine, but won't steam
contact Shark . they will know better and faster than we could find it .
Oct 20, 2015 | Shark S3501 Steam Pocket Floor Mop With 5...
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
HEAD BLOWS OFF
Likely the cause is a blocked hose in the head. See my video post for explanation of how to fix it:
Shark Steam Mop Repair DIY Heater Core Cleaning
Feb 20, 2014 | Shark S3501 Steam Pocket Floor Mop With 5...
The Shark mop gets warm but does not produce steam. This is the second mop I have owned. Bought a new one as I had the same problem with the first.
Just a guess, but I think you have hard water problems. Pour some vinegar into the mop, heat it, allow to cool, pour it out, rinse, repeat. Afterwards, use distilled water if available, otherwise, after every 5 - 10 uses, use the vinegar to remove the minerals from the heating elements. Let us know if this works!
Dec 21, 2012 | Shark S3501 Steam Pocket Floor Mop With 5...
I am noticing that my hardwood floor looks streaked and cloudy after I use my shark steam mop, I even tried using distilled water and it did the same thing. Any suggestions on how to fix that?
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems heatman101
Jan 23, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I used your shark steam mop on my hardwood flooring and it took the shiny finish off, what now.
heatman101
Jan 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam mop S3501. I just bought this a month ago and now when I plus it in it does not come on. What can I do?
heatman101
g
Nov 07, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Poor cleaning
Oct 27, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
602 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
