Question about Toshiba mini NB205N325PK 101" Netbook Posh Pink (PLL23U00T01C)
Bosh fabric softener not filling with water to
Bosh fabric softener compartment not filling with water to create siphon, Hasn't worked on any cycle. Took washer top off, moved control panel out of the way, disconnected all hoses both supply and drain and cleaned well. Water will flow into detergent compartment and the bleach compartment (strong flow) but no water flows into the fabric softener compartment. If I pour water into the fabric compartment it will siphon until empty. Everything seems seated properly, Did not find clog or broken plastic.
What is my next step?
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: My KitchenAid KUDK03ITBL dishwasher will not get
Possible fault, the timer has stopped working and therefore won't advance to the next wash cycle.
Posted on Jun 10, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
After filling compartments correctly and closing the tray, I see the fabric softener emptying into the washer. Tray does not leak softener when removed and filled.
You are putting too much in there... the tray empties on a siphon priciple... if you fill it too high it will just siphon out...
Use less fabric softener...
heatman101
Dec 13, 2010 | Kenmore Elite HE5t Washer
My spin cycle will not finish and I get a code F 03.
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore 44072 Front Load Washer
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Code F3 displayed and it won't begin cycle.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 03, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code
Apr 12, 2009 | Washing Machines
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Toshiba mini NB205N325PK 101" Netbook  Posh Pink (PLL23U00T01C) Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
