Question about Kenmore 24032\24036 Top Load Washer
Water filled...attempts to start the wash cycle, but stops. will not wash, spin, or drain.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: (MOST LIKELY THE FIRST)
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on May 15, 2010
SOURCE: fixn my GE washer spin cycle
you are correct, the "leak" was from the over flow, and the "no spin" were all caused by the incorrect level indication. could not blow out the tubing so I replaced it...everything works fine now. thanks for your help!
Posted on Jun 27, 2008
SOURCE: WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Posted on Dec 07, 2008
  • 86 Answers
SOURCE: Control panel reads E61 at wash cycle and E66 and drain and spin
Can you tell me what make this machine is? As it sounds like a heater problem??
Posted on Dec 28, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    59 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
