Question about Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE BREAKER I TURNED SAW ON AND CIRCUIT BREAKER TRIPPED AGAIN. ANY HELP.
    Scholar:
  • 130 Answers
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
Posted on May 16, 2010
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
I was recently given and older Craftsman 10" table sawa. It worked great for cuttin some 2x4 and now all of a sudden it will only cut part way7 and than stops, and it smokes--Help!!
The problem could be one of the following:
1) dull blade, in which case replace with a carbide-toothed blade
2) underpowered or old/faulty electric motor
3) faulty/worn belt, in which case replace with new belt
4) The pulley on either the motor or the saw arbor (where the pulley attaches underneath the saw near blade) could be loose. Tighten down set screw.
5) The saw fence isn't set straight causing the wood to jam as you push it into the blade. Check this with a framing square and readjust so it is at a 90-degree angle to the front of the saw table.
Sep 13, 2011 | Craftsman 10" Table Saw
I have an older model 12 in table saw every once and awhile motor will start t smoke after using only a couple mn.
The motor or the wood piece your try to cut? because if the motor is "smoking" i bet it do it once.So change the saw blade and post back please.
Oct 12, 2010 | Craftsman 10" Table Saw
Have a craftsman 10 inch table saw model #137.218250, serial #RCW3145. When we attempt to cut plywood or a 2X4 length ways, the motor dies a number of times. Most of the time the reset button will not...
sounds like the reset button needs replaced. Also when is the last time you cleaned the motor area?? When you reset the button is the motor "hot" to the touch and if so could also be a motor problem,, try the reset first
Aug 26, 2010 | Saws
I have a craftsman radial arm saw 113.23100 which has not been used for possibly 20 years. I cannot get the motor to rotate in order to make 45% angle beveled cuts. I have turned the bevel lock knob to the...
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Jun 27, 2010 | Skil 10" Table Saw
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Jul 18, 2009 | Craftsman 10" Table Saw
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
986 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
