Question about Dishwashers
Dishwasher door latch
My dishwasher door is closed and stuck. Something in the latch mechanism seems to have broken and I cannot open the door. The lever/latch located in center and underneath the console feels loose and not completely attached. How do I open the door? I have the same problem latch stuck up inside dishwasher and can't open now, its a whirlpool don't know the model# I have a "DeGree" under-bench dishwasher - can't find anything about it on the web, so I assume it's a re-badged brand. Door latch is stuck and there are no screws to gain access. Have pulled the D/W out from under the bench and can see the latch when I look from the side of the door. I have fed a heavy wire through the side and tried to lift the latch, but it's stuck fast. Any other suggestions?
  • 2 more comments
  • Marc Segan Mar 31, 2008
    I have just about the exact problem. Any help is appreciated!
  • janiet Oct 06, 2008
    I think my husband opened the dishwasher when it was drying; now the door hangs on the left side. Any suggestions?
  • mgm8662 Jan 17, 2009
    same problem we took the cover off of course small plastic piece on latch is broken. Can we order new latch assembly.
  • Anonymous Apr 20, 2009
    GE Profile dishwasher door will not open.
Its very east to open. Take the top cover plate off the appliance, undoing the screws at tha back and it will reveal the latch.
regards
george
Posted on Oct 27, 2008
If it is a LG type, it is fitted with an overcentre type latch.
There is no need to remove anything. Wedge your fingers behind the door and thumbs on the front cover.
Apply pressure on the door - that is all that is required. Try to do it evenly, i.e. same pressure both sides, otherwise you may bend the door. Boykie
Posted on Oct 06, 2012
    President:
  • 1,314 Answers
Send me an e mail at [email protected] i may have something that will work on whirlpool and kitchenaide maybe westinghouse too dont know
Posted on Mar 30, 2008
SOURCE:
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Sep 14, 2010 | Magic Chef CDB1500AW 24 in Builtin...
We have a one drawer type dishwasher in our new motorhome and no pamplet seems to be enclosed. Could you please tell me how to lock it!! I does come pen when traveling! thank you.
Most dishwashers either have a latch located at the top that you must slide to the right, or have a mechanism that should lock it anytime the door is closed. Look at the top of the dishwasher door, if it's just a handle then it has the mechanism. Look at the handle for the door. There should be a lever within the handle that disengages the latch. There could be something broken within the door mechanism. You should see the catch on top of the door and receiver on the underside of the top portion of the dishwasher housing.
Jul 03, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Dec 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
1,294 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
