Question about Kenmore 63252 Microwave Oven
Kenmore Microwave 721.66319 500 Light buld gone out - now what?
Christmas 2006 I received as a gift the Kenmore table-top Microwave. Now just over a year the inside light no longer comes on. I thought it would be an easy fix by just changing the bulb. I can't find the bulb.
Upon doing research I see where I'd probably need special tools and then I'd have to remove casing, etc. Why in the world did Kenmore make a light that hardly lasts a year and that would take a repairman to fix? This is a racket.
Can I not somehow fix myself without it costing an arm and a leg. This is ridiculous and costly to a cheaper appliance. Microwaves shouldn't require all this fixing of bulbs.
I called Sears to see what I should do and they said since I didn't buy the extended warranty they couldn't help me or offer advice. I hate to pay 100.00+ dollars to fix a bulb. Any ideas on this? Thanks so much.
I will never ever buy kenmore again.
  • Jessica Smith Apr 01, 2008
    Thanks for the reply. I called Sears back and they quoted me a price of 59.00 for the bulb. They also said the screws would require a special tool to unscrew the casing. It looks like a Philips with a metal piece coming up in the middle so you can't use a regular Philips.
    It appears Kenmore/Sears doesn't want one to fix on their own. This is a simple light that should have lasted more than just over a year. That's ridiculous. I'll just microwave in the dark.
    Thanks so so much for your reply though.
  • Kenmore Master
  • 9,098 Answers
First of all, since this will involve disassembly, we have *critical* safety & disassembly info at our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams for your Kenmore model here: http://www.searspartsdirect.com
Enter your model number as 721.66319500.
The light bulb is shown in the "LATCH BOARD PARTS" diagram and it's located in the area of the door switches.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
It's best not to touch the bulb with bare skin, as the oils can shorten thee bulb's life. And I recommend a high quality bulb from places like Home Depot, instead of cheap types from the grocery store.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
My Hamilton Beach Microwave no longer gets hot. I received as a gift for Christmas.
then tell the person that gifted it to take it in for service under warranty .
Mar 31, 2015 | Hamilton Beach Microwave Ovens
Fix a kenmore microwave turn table model 721.80012401will not turn
http://www.ebay.co.uk/sch/i.html?_odkw=kenmore+microwave&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xkenmore+microwave+motor&_nkw=kenmore+microwave+motor&_sacat=0
Aug 11, 2014 | Kenmore Microwave Ovens
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
The Microwave Oven with glass Round Turntable, floor with white paint gifted by my newphew from America during 2006 has stopped working. The power chard checked and found ok. Equipment is receiving...
Your oven Thermostat has tripped. This can happen either from cooking something too long and the bi medal didn't cool down correctly or a loose wire connector to the thermostat causing it to go out.
This part is located on the very top of the microwave under the cover. part#AP2026103. You can find on this page #61 on the picture. Stay clear of #49 that is a High Voltage Capacitor and can hold a charge up to 4,000volts. Professional Techs know how to discharge it easily and work safely.
With that part changed you will get power back to the board and be able to use your microwave again.
Dec 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
The turn table won't turn
Fixed the problem by returning it for a different machine.
Dec 25, 2009 | Panasonic Microwave Ovens
How to change light bulb? The light that goes on when the microwave is working burned out. How do I change it?
remove the vent cover on the top of the unit above the door
two srews should be holding it down from the top
slide the vent off
you should see a mtal plate
remove that and the buld should be underneath
Oct 27, 2009 | Kenmore 63672 Convection/Microwave Oven
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
I have a recently purchased microwave since CHristmas. It was working wonderfully. Recently, I moved and plugged the microwave back in. THe light is on but will not program anything. I tried to plug into...
We have the same model. It's a piece of garbage. I loved the retro oval window and all and the size was perfect for our space. Then, the paint started chipping off the inside front, the timer started working intermittently, and the oven would just quit in the middle of the cooking cycle! Today, it finally just up and died. I unplugged and replugged it. No go. Finished cooking on stove top. My suggestion? Do like we're going to do and go buy another microwave...not another GE!
Good luck! Peacenikkie@charter.net
Jul 06, 2008 | Microwave Ovens
Pop pop Kenmore hood microwave 665.60652 - year 2002
hmmmm, i wonder if you have a gear or something similiar to this going out. (turn tables)
If not, something tells me you have a component that is arching inside of your micrwave. I would call someone to double check to make sure it is ok.
You will be surprised at how many people wait until it is too late to service their units, when it goes out, it is gone.
good luck
May 25, 2008 | Kenmore 62702 Microwave Oven
Turn table wont shut off
This is most likely a problem with a door switch or a stuck relay or other problem on the circuit board. We have important safety information and information about door switches at our site. Our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need help with a control panel repair, we fix them nationwide for $32.50 postpaid in most cases.
Feb 23, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 63252 Microwave Oven Logo
417 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
