Kenwood RXD-A53 CD player just rotates and doesn't load a CD, also, when the open door button is pushed nothing happens, the radio and cassette player work fine, help!
  • svksmc May 15, 2010
    Super quick response, haven't tried the solution but I will, Thanx!Will the lense cleaner also fix the open door button problem?
  • 6,993 Answers
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Posted on May 15, 2010
Testimonial: "Super quick response, haven't tried the solution but I will, Thanx!"
  • Walesarumi
    Walesarumi May 16, 2010
    not really, the lens might not fix that. But the lens could also be the cause of that because, when its trying to load the data on the disc it might hang the unit and not allow the open button respond on time.
    Secondly, the opening door problem might be a cause from the open/close button, or from the mechanism, or from the disc tray.
    Just open that player and troubleshoot the open/close are and likewise the mechanism and disc tray.
    Take care
My car audio system, an original toyota radio, has buttons for both Tape and CD but only a Tape slot, what could the CD button be for?
If that was the case, the face of the radio would open up exposing the CD slot when you push the button, maybe the face is stuck.
Sep 11, 2012 | Cars & Trucks
Cassette door will not open
below the push button their is a tiny whole , take a needle of about 3---4 inches in length and insert in that whole and your door will slightly comes out then open it with your fingers
Jun 14, 2010 | Audio Players & Recorders
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
'99 Mercurary Tracer cassette player problems...
The cassette adapters are notorious for getting stuck in the deck. More often than not its the wire that comes out of it that causes it. The cleanest and safest way to remove the cassette adapter is to remove the radio, take off the top and "Help" it eject with your fingers or some narrow tool that may get behind it to push it forward and out. If you dont want to take the deck out of the dash, you can try pushing the eject button while manipulating the adapter wire, but I dont recommend it. Its just better to take the deck out. Good Luck
Feb 06, 2009 | Car Audio & Video
Kenwood shelf sysem RXD-A53
Dear Lorita,
Please load lens cleaning cd in the system. the lens need cleaning.
ramesh22
Jun 06, 2008 | Audio Players & Recorders
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
Door Opens then closes and Powers Off
Try holding down BUTTON [5], then press the RESET button (you'll need a ballpen between the AUTO and SCRL buttons). This worked on the KDC-MP825 (very similar to the MPV8025) when my wife had the same problem this month.
May 21, 2007 | Kenwood KDC-MPV8025 CD Player
508 people viewed this question
 Grubhead
Grubhead
