Question about Refrigerators
Admiral refrigerator my admiral refrigerator is just over 2 years and yesterday it quit getting cold. I lost everything in it. It sounds like a fan is running all the time but my entire unit is not cold.
  • ZarahTom Apr 16, 2008
    I have the same problem! Did you find anything out? Cheers
  • 109 Answers
Sounds like the compressor is bad, do you hear a clicking sound when you turn it on or when it's trying to turn on?
Posted on Mar 31, 2008
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
Refer does not work. Freezer and ice maker work good.
Check your evaporator fan in your freezer. They go quite frequently these days. The fridge gets it's cold air from the freezer via the evaporator fan blowing the cold air down into the fridge and cooling it.
Jun 30, 2011 | Admiral Refrigerators
Freezer part is working fine. fridge part is barely cool on the highest setting
Sounds like your cooling tube ia blocked by an ice buildup or something. Some refrigerators have a fan to draw the cold from the freezer to the refrigerator and if the fan quits, then the cold is not drawn out of the freezer.
If it isn't a frost free freezer then it is probably just a case of needing to defrost the freezer.
Jun 01, 2011 | Admiral Refrigerators
My refrigerator is 9 years old and yesterday it started thawing everything out it is running but not keeping anything cold
If the compressor is running and the fan under the unit I am afraid you need to buy a new fridge. This normally means its low on freon you could have a repairman add some but at 9 years old I would recommend a replacement. But make sure the compressor is running and not just the fan the compressor will hum.
Aug 16, 2010 | Whirlpool Refrigerators
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
I have an admiral refrigarator but it doesnt get cold both sides
Sounds like a bad freezer fan motor .(in the freezer section)
Aug 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Admiral Refrigerator Model HMG671581 bought from Montgomery Ward 9 years ago.
Thanks for the chat
I really belive after 20 years of service on home appliances this is the problem with your unit. If you call a repair company to come out and it is not the issue (dirty Condenser ) I will refund your money on this chat.. Sound fair?? my email is gary@appliancedoctors.ky please email me and let me know...Have a great day
Jan 29, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
