Question about Garden
Runs 30-45 mins then shuts off
I have a craftsman riding mower model #917.255450. it will run 30-45 mins then shut off. after 20 mins or so of setting it will start again as if there is a heat sensor malfunction. it will not spark until it cools down. is this a sensor problem and if so where is it so i can replace it?
    President:
  • 1,627 Answers
Sounds like you need to replace the ignition coil,it may have leaked out it's coolant and the it will go to ground when it is hot.
Posted on May 17, 2010
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Idles fine, shuts down when release brake.
It could be the brake switch bad, if this model came with one. When it is depressed it will start, but when it is released it may not be switching to stay running.
Mar 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The engine runs for less than 2 mins and shuts off
could be oil low cut off , dirty air filter ,check fuel filter.
Oct 05, 2009 | Craftsman Garden
Mower shuts off after running for 20 mins. then you have to wait 10 mins to start again.
Sounds like you have something intermittent and its going to be hard to isolate. After it shuts off will the motor still turn if so see if its getting fire.
Sep 29, 2009 | Craftsman Garden
Mower shuts off while mowing grass
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawnmower shuts off after 15 - 20 mins.
I have a Troy-Bilt push mower that does the same.
Try this - Run the mower until the point of quitting. Keep the hood up and be ready to remove the gas cap. As soon as you feel it start to stutter like it's going to quit, unscrew the gas cap and see if it comes back to life and doesn't quit.
If that works, then what is happening is that the gas in the carburetor bowl is getting depleted faster than the tank can provide it, possibly because of a clogged vent that's supposed to allow air back into the gas tank as gas is used.
You can try running with the gas cap not quite tight, to let some air seep in that way, but that's more prone to sloshing leaks. You could also try drilling a hole in the gas cap - about 3/16" is plenty, and stuffing a piece of natural sponge in to keep the gas in and dirt out. Synthetic sponge will deteriorate in gas.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
