Question about GPS
I have a cobra 21 ltd wx cb radio. it gets the weather cannel fine but when switched to cb it gets nothing in or out. if you hold the unit to you ear i can still hear the weather channel faintly what might be causeing that to happen?
    President:
  • 2,468 Answers
Check the antenna system whether single or dual mounts,you have a shorted coaxial cable,if dual mounts then just replace the co-phase coax from both antennas to the c.b radio,then check and make sure you also have good grounds at the mirror mounts if this is the set-up you have,then have the S.W.R. on the unit checked
Posted on May 16, 2010
  • darklord6667 May 16, 2010
    hi thanx for they reply. i know the antenna is ok its a k40 and im useing it on another radio right now and its working fine. any other thoughts would be great. thanx
  • danny Hendrickson May 16, 2010
    just for the heck of it change the microphone,or take a pocket knife with the microphone unplugged from the radio and touch 2 terminals where the mic connects there are 4 pins try 2 at a time till you get audio,one way will show transmit,the other will give you audio.... try up/down....side to side.....diagonally touching the pins,it won't hurt the radio,this will rule out the microphone,thanks for the rating.....let me know the outcome..... thx
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Size fuse for cobra 25 ltd wx
hi please insert a 6amp fuse on the dc positive line it will work fine with this
Nov 04, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
My 18 WX ST Cobra CB radio will allow me to receive sound from the 3 weather stations it has on it, but I cannot pick up sound from other CB radios. help please?
get an swr meter and check your antenna first. if good problem may be in the circuit board.. they are famous for loose IF, TX mixer boards. or call us
Nov 03, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
COBRA 29 WX NW ST
have somebody look and see if there are any bad solder joints inside the radio...
Jan 10, 2009 | Cobra 29 LTD CB Radio
Wx stations disappeared
They did not put all the plugs back in from the weather board. Part of what has to be fiddled with is underneath the weather board.
Open the bottom cover where the speaker is, on the right side you will see a board separate from the main board. Look for any plugs unplugged. Its probably one that got over looked.
If there are no plugs out, who ever you took it too may have turned something they should not have. most likely its a plug. Its probably the plug that runs the audio into the radio from the weather board. its working, the audio just isn't getting to the rest of the radio.
there are about 3 or 4 plugs from the weather board to the main board of the radio.
Nov 10, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
NO sound
Make sure the switch is in the CB position. If this is so, then you may have a bad switching transistor or a bad diode in the board. Also on some of the weather band cobras I have worked on in the past, I have found bad pll chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
