Question about Whirlpool GEW9250 Electric Dryer
I lost my owners manual. i need to switch the factory plug back. the colors are red, white, green and black...how is the setup supposed to be
  • 8,197 Answers
Here is a picture to help you hook it up. The white wire is in the midel. You can not see it.
http://www.applianceaid.com/images/ldr-cord-4-wire.jpg
You can also get the manual on link below.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gew9250&siteCd=WHRCOM&userType=Consumer
Posted on May 15, 2010
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1993
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Constant 12V+: Blue/White
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
I have a 2001 F150 and am trying to find out where the factory installed plug in is for the brake controller wiring. I have the brake controller and the instructions say to read the truck owners manual...
Hi. There is a grey plug with 6 wires right behind your OBDII diagnostic port on the lower dash board above your accelerator pedal.
The color of the wires on the plug are blue, green, red, white and brown. The wires are as follows:
Blue....electric trailer brake feed
Green....brake pedal switch
Red...12v postitive...always hot
White....ground
Brown....interior vehicle illumination (not used)
The factory wire harness that you will need to attach your brake controller will plug right into this plug. The factory wires are colored the same as above.
After-market and brake conroller wires are colored as follows:
Red.....brake pedal switch
White....ground
Black....12v positive
Sep 01, 2010 | 2001 Ford F150 Styleside SuperCrew
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
1988
1989
1990
1991
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Accessory: Blue/White - Ignition Switch Harness
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
1984, 1985:70-1388
1986, 1987:70-1720
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
1983
Illumination: n/a
Dimmer: n/a
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (-) Gray/Black
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Whirlpool GEW9250 Electric Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
