Question about LG MV-1444Y Microwave Oven
Microwave wont heat, but magnatron is good.
I tested the magnatron with my meter.
  • 5,603 Answers
I seriously doubt you could test a magnetron with any meter you have. It would take a 5000 volt source to check the emission and then a microwave power meter to check the output. The filament which is the only thing you could test with an ohmmeter rarely go out. Overheating and gas formation are the common failures.
There is often a high voltage diode that rectifies the power from a current limiting transformer. These do go bad at times. Since they have many junctions in series to take the voltage, they are not easily checked with a meter like single diodes are tested.
Remember there is about 5000 volts from that transformer during operation.
Posted on May 15, 2010
LG Microwave not heating
there are two censors inside one high heat one low heat they can be checked with a meter if both are good its a bad magnatron and exceeds its worth
Mar 05, 2013 | GE JVM1650 1000 Watts Microwave Oven
My singer microwave oven does not heat anything!
Hi fionalamplou ,
Plz specify the model no of the microwave to get proper answer however it Sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnatron, they replace the whole oven.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.
Aug 22, 2011 | Microwave Ovens
Microwabe is not heating anything
Jun 12, 2011 | Samsung SMH9187ST Microwave Oven
Mm5165bas, light comes on, fan works,carousel doesn't work , does not heat.
Hi, it sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
May 08, 2011 | Maytag MMV5165 Microwave Oven
Microwave runs and sound normal but nothing gets hot.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 07, 2011 | Microwave Ovens
Maytag microwave is not heating and the time runs back fast.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.............
May 07, 2011 | Maytag Appliances Over-the-Range Microwave...
How to check a magnatron in a microwave Microwave runs but does not heat
use the amper meter or clamp meter ,magnatron heck first physically then check coil continuty check the HV diode&pcb also
Aug 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Strange noise, no heat
Feb 02, 2009 | Emerson Black Microwave Oven
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
May 02, 2008 | Microwave Ovens
LG MV-1444Y Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
