Question about Biostar P4M900-M4 Motherboard
My client has a p4m900-m4 mobo that was installed Oct. 2009. The system has 2 dvd players. He tried to play a dvd and the system shut off and now appears dead. I get a power light, one of the dvd players blinks but nothing else happens. All fans are running. There is no display, not even the biostar logo. The hard drive light does not come on. I am getting the proper voltages from the power supply but have tried a different ps just in case. Same result. If I remove the memory I get no beeps. Is my mobo dead?
  • 728 Answers
Hi
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or HDD or whatever as long as it's a drive) the CPU, graphics card (if required) and one bank of memory, unless the board requires dual matching chips.. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drives, make sure you set your pin settings for master/slave/CS are set correctly on it. Now, you should get the power supply on, and the cpu fan spinning. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or finally the motherboard. The next step is to replace each one of the elements with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that. I usally start with the drive, then move to the memory chip, next CPU, Last PSU. I also make sure that my replacements work on another machine first. If no change, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Please don't forget to leave a rating.
Thanks Mark
Posted on May 15, 2010
  • 66 Answers
Yes the mobo is dead . to confirm remove everything off the board . except the power from the psu. pull the ram one by one if there is no beep dead motherboard
I want gat audio and video driver for mypic p4m900-m4
The drivers should be available here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=402
You should be able to download the drivers you are looking for there. Make sure you pick the correct drivers for your video card (under VGA) and your sound card (under audio), and ensure that you download them for the operating system you are using. (For Windows 7, Vista drivers should be sufficient.)
You should also take a moment to install the on-board LAN drivers as well.
Jul 09, 2011 | Biostar P4M900-M4 Motherboard
I HAVE A P4M900-M4 MOTHERBOARD, MY PROBLEM IS THERE IS NO VIDEO OUTPUT (NO SIGNAL), NO BEEP? CAN YOU HELP ME
First thing to try would be a full cmos reset, most motherboards will accomplish this if you remove the cmos battery overnight then replace and start the machine back up
May 03, 2011 | Biostar P4M900-M4 Motherboard
How to install my graphic option in to my pc.my motherboard is biostar
my Biostar P4M900-M4 Motherboard cannot detect my pci-e graphic card,i use msi N8400GS 512MB DDR2,when ion my pc show no signal
Aug 18, 2010 | Biostar P4M900-M4 Motherboard
here you will find the list of drivers for the p4m900-m4 motherboard
http://www.biostar.com.tw/app/es/mb/driver.php?S_ID=283
Aug 16, 2010 | Biostar P4M900-M4 Motherboard
Installed new P4M900-M4 MB. System will not boot up. Screen shows startup but when I press the delete button for setup, nothing happens the message 01/17/2009-P4M900-8237A-6A7L8B06C-00 pressing any ke has...
Hi rhvc59,
Something isn't setup correctly on the board. There could be many things that could stop the system from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board. But if you are successful on all equipment, then it was worth doing it one by one.
Good Luck
Mark
Nov 13, 2009 | Biostar P4M900-M4 Motherboard
Installed new P4M900-M4 MB. System will not boot up. Screen shows startup but when I press the delete button for setup, it just sits there. At the bottom it says "entering setup", but goes nowhere.
First reattach all connection top motherbord.
Refix RAM memory.
Pull cmos cell for 15 minutes from motherbord so all bios settings are reset.
heck your power supply unit of computer working fine.
Aug 08, 2009 | Biostar P4M900-M4 Motherboard
Cann't find the VGA driver for my P4m900-M4 (onboard Driver)
Drivers you need can be found at Biostar's website here:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=283
Download the driver you need for your system from that page.
Feb 09, 2009 | Intel Computers & Internet
Emachines220 celron 2.5 gig
I've had 2 emachines t2682s with celeron 2.6ghz procs, go bad. From my research it seems that the PSU goes out and takes the mobo with it. just this week i am updating the latest fatality. Thought i had the fix but new mobo only supports celeron D and P4. Just ordered new proc. Should have changed it all over to AMD like I did with the last one. Good luck finding the right mobo with 2 pata ide sockets. I'm currently trying to use a biostar P4M900-M4 but need to upgrade RAM and CPU. Could have gone with an AMD dual core set-up for same dough. Hope this helps some.
Apr 08, 2008 | E-Machines Athlon XP 2200+ (rb-t2200-c67)
Biostar P4M900-M4 Motherboard Logo
161 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
