Question about Microsoft Xbox 360 Console
Previously my video was not woking but the audio was on my Xbox 360 . I then replaced the old input/output audio/video jack with a new HDMI input/output jack and now nothing is coming through (audio or video). Do you know what could be the problem?
    Problem Solver:
  • 16 Answers
It depends on your tv if hd tv theres a switch on one of the jacks switch that to hd if non hd then ull have to get a non HDMI lead
Posted on May 15, 2010
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
Static during Gameplay!
try using a different tv or different speakers. i use a audio converter that truns the two audio inputs from the xbox into a standard headphone jack that i hook up to a computers input or a speaker set with a headphone jack with two imputs for a headphone javks
Sep 29, 2009 | Microsoft Xbox 360 Console
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Dec 30, 2008 | Sony STR-DG520 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
