Question about Sharp XE-A402 Electronic Cash Register
The screen displays E 3.2 when I try to ring up a sale. What do I do to correct it? When I enter 2.00 and the ! for the item number. Then hit total the screen displays E3.2 but won't add the sale up. The model 3 is XEA-205. I have owned the cash register for 5 years
  • 360 Answers
Ok press 1 and press clk key
Posted on Jul 12, 2010
I have a sharp ER-A330 register.. it will let me enter a cashier #, but it will not ring a sale. It is not in calculator mode, it does not have a sale on it, the drawer is not stuck . I m confused .
It is easy to know if you have logged on a cashier correctly. After entering the cashier, you will see hyphens around the cashier number on the display. For example, if you sign on as cashier 1, you will then see -01- on the display. If not, you haven't logged on and you will get a longer beep when you try to use department buttons which means please log on.
Apr 19, 2017 | Retail Supplies
Casio T-280; I need to cancel out a transaction. Haven't hit cash/check/charge; I want to do this without having to issue a refund
This machine is too cheap to have a void function so you will need to finish the sale with cash. Now you can reverse the transaction:
Turn the key to RF mode. Enter the items exactly as you did the first time. they will all be negative items now and they will go back out of the daily sales. Finish the sale with the same payment type (cash) and the machine will take the amount back out of the cash total. Now your sales report will have the correct figures.
If you want an easier method, buy a Casio with the CANCEL function and you can quit a sale at any time :)
If anyone needs a Casio PCR-T280 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T280_operating_and_programming_manual.html
Oct 19, 2013 | Casio Parts Cash Register PC Desktop
Entering several PLU programmed items on one sale
Go into your Options>settings (or some have it the other way around) and look for a setting called "print after PLU input" or something similar.
Aug 31, 2017 | Computers & Internet
Entering several PLU items on a paticular sale (one sale).
Submitting multiple postings for the same fault will not get it answered any faster. Please try not to do this.
May 02, 2013 | Computers & Internet
I was a away and my staff screwed up my casio TK 2700. I had already started a problem when I tried to change the tax on one item. Suddenly a lot of keys were reading condiment. However my staff member...
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
That will jump the machine out of the sale.
Now, while still in program mode, 3 SUBTOTAL (display should show P3) 0 Now press an item with condiment problem. If you have a few items with this problem, press 0 before each item. SUBTOTAL
Now turn back to REG and try them in a sale. If they work, you can go back to programming them correctly.
If anyone needs more information, the TK2700 programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-2300_and_TK-2700_and_CE-4700_programming_manual.html
Jul 02, 2011 | Casio Parts Cash Register PC Desktop
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
HOW DO I CALCULATE STANDARD DEVIATION FOR CALCULATOR T1-30XA
Hi dear friend,
I am providing it with an example.
- I am sorry that the instructions from the maker of the calculator on how to calculate a standard deviation fell short of your expectations. All you have to do is follow them key stroke for key stoke, but enter your own data. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
I hope this will help you. Please vote for me.
Thanks in advance.
Jan 30, 2010 | Texas Instruments TI-30XA Calculator
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
Sales transaction
Pusedo is as follows
/get the cost of them items and add it to the total
when no onter items are found exit loop
if there are items continue loop //
item = y
total = 0
do while item = y
total = item + total
get cost of new item
if cost = 0 then item = n
loop
Print "BILL TOTAL = " + total
// minus discount
enter discount amt (in %) as da
discount = (da/100) * total
total = total - da
Print "DISCOUNT = " + discount
Print "new total " + total
//add vat
vat = (12/100) * total
total = total + vat
Print "VAT " + vat
Print "new Total " + total
//get pay
enter amt paid as amt
change = amt - total
Print "Paid " + amt
Print "change " + change
Print THANK YOU FOR SHOPPING AT FIXYA
Feb 20, 2008 | Computers & Internet
Sharp XE-A402 Electronic Cash Register Logo
294 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
