Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Default setting Printer How do I know the correct version of the printer driver is set as the default?
    President:
  • 1,561 Answers
Hello, Click on start, go to control panel and click, go to printer and faxes and click on it, it will display all the printer that as been install to your system, to determine which printer is set as default, you will see a printer that is mark, that is the printer that is set at default. To set your own version of printer at default, all you need do is after the installation of the printer driver, follow the above procedure and click on your printer, after clicking on your installed printer, at the top left corner, you will see printer, click on the printer, you will set printer as default, click on set printer as default and the printer you select will be set as default. Any time you want to print, it is the printer that you set as default that will print your document. Take care.
Posted on May 15, 2010
Error 5
If no default printer is selected, or no printer driver is installed, Printer Error #5 is displayed.
Select a default printer in Windows by going to your Control Panel > Printers. Highlight your Printer and go to File on then Menu Bar and choosing Set as Default.
If the correct printer is already set as the default, and you get Error #5, try setting another printer as the default printer. Then select and set the desired printer as the default, and reboot the machine. This sometimes clears the problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 15, 2013 | Canon PIXMA MP150 All-In-One InkJet...
HI, I have sharp ar 5316 printer. I have a software which doesnt call for the printer details. For this reason I have to set default from printer settings in control panel. Now the problem is the file is...
first of all download correct version of printer software from sharp site or driver download site.then install the driver first without connection the machine .when driver asks connect the machine and it will do the rest. by using default driver u cant have the features
May 26, 2011 | Sharp AR-5316 Advanced Digital Imager...
I want to make my wireless hp office jet 4500 my default printer
  1. Click on the Start menu and click on Settings, then Printers.
  2. 2
    A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  3. 3
    Click on Set as Default.
  4. 4
    To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz1BoplOTlM
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
How to set printer as default
  • Click on the Start menu and click on Settings, then Printers.
  • A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  • Click on Set as Default
  • To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
  • Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz14tGsLTEN
    please leave feedback if this helped you :)))
    Nov 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
    Will not print material from the internet.
    Open up the Printer Properties icon on your computer. Its location varies with OS versions, but typically click on Start, then Control Panel then Printers. Make sure your printer driver is correctly installed. Select the FAX choice and see what is set up to function as Fax; the only reason that programs call up the Fax would be if the Fax is defined as your default printer. Suggest an actual printer and set the printer as Default; printer problems should be solved. Problems? contact Jaye Ellen at jaye.ellen@gmail.com
    Apr 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    Prints a single line of gibberish on 1 page before printing the document, then eventually spits out a blank page. Running on vista, using vista driver. Dell 1720dn printer on Vista Business SP2
    Gibberish? What you are seeing may be printer control codes and data.
    Is there any way you can scan the page into an e-mail and then send it to me at don.farr@verizon.net, please.
    I'd like to see your printout.
    Don
    Nov 04, 2009 | Dell 1720dn Laser Printer
    Quickbooks Pro 2007 Printing Blank Invoices
    Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
    Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
    If the above are set correctly, go to HP's website and download the latest driver for your printer.
    Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
    How to set to default printer
    Install the software first, then connect the printer. Once all drivers are installed go to start, settings, printers. Find the printer, right mouse click on it and choose "set as default printer", that's it.
    Let me know how it works out for you.
    Nov 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    Scanner & Printer X3470
    You first need to download and install drivers here:
    DRIVERS & DOWNLOADS -- Lexmark.
    Unplug printer before installing drivers.
    Aug 31, 2008 | Lexmark X3470 All-In-One InkJet Printer
    HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
    46 people viewed this question
    Seeker5211
    Seeker5211
