Question about Hotpoint Dryers
Hotpoint aquarius VDT60 fault F-15 keeps
Hotpoint aquarius VDT60 fault F-15 keeps coming up
  • 8,197 Answers
F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
Posted on May 15, 2010
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
My hotpoint aquarius wmf720 keeps flashing either door or f-10, can anyone help??
Please read in full before attempting any repair.
p.s. Before working on machine "turn of the power".
Only carry out if you are confident that you can carry out safely.
Note check small black hose to the air pressure switch is connected,
When machine is turned upside down, the hose has a tendency to come off.
If unsure call a service engineer.
My machine just had the flashing "door" fault.
On carrying out fault finding checks,
I Found that the main PCB had a built up dust.
This dust was in black lines going between components of the board.
Cleaned around components of the board with a small soft brush.
assembled & tested okay 2 months ago & still working.
Mar 31, 2013 | Hotpoint Aquarius WD640 Front Load...
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
My HOTPOINT Aquarius + super silent will not tumble dry. it starts off OK but then comes up with Error code F-13 can you tell me what this means
Hello
F 13 is a fault code for water supply,inlet valve or hose connections.
You may try unplugging the machine and plugging back in to reset.
Mar 31, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dryers Logo
386 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
