Question about Candy Dryers
I have a candy go dc218 condenser tumble dryer not working
I have a candy go dc218 condenser tumble dryer, it was working fine then i smelt an electrical burning smell and immeadiatly opened the door. I removed the load and could see the elements still glowing at the back until they just went off. Now when i try and use it there is no heat and when i open the door the drum stops but after a couple of seconds blips on and stops. Does anybody know what i will need to repair the fault and fix thanks
  • 209 Answers
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
Posted on Sep 29, 2007
  • 833 Answers
SOURCE: cic60 candy tumble dryer
Generally, these units are gotten into from the back panel. Be sure to disconnect the power. There are two breakers linked together.
Posted on Dec 18, 2007
Jimster
  • 240 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER - HEATER SHUTS OFF PREMATURELY
First off, how are you looking to check this situation. Either way, it would be normal for this to happen. When you are looking at the elements heating, you more than likely have the door open to see them. The heater will do what they call "short cycling" because the airflow has outside source air getting into the heat stream. The door and lid almost always has to be shut for this system to work correctly. You can sometimes crack the top just enough to see the element heat. Usually, if the element is coming on at all, then the system should be fine. If you have a dryer thats not drying your clothes completely, its more than likely you have a ventilation issue (i.e vent tube restriction, grass growing in the end of the vent, etc). Also remember these Maytags have two thermostats on them most of the time. One directly over the top of the element, and one in the fan housing at the front of the unit. Try those, if there isnt a change, write me back and will look from there. Good Luck!!!!
Posted on Feb 02, 2008
  • 236 Answers
SOURCE: Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
Candy condenser tumble dryer Gcc 590nb-80 How do I get at the capacitor to change it. I've taken the top panel off but the 2 sides and back is in one piece.
Go to www.repairclinic.com and enter Gcc 590nb-80. You will be presented with a list of common replacement parts and may be able to view a generic video showing disassembly with identification of parts.
Oct 31, 2016 | Candy Dryers
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Can anyone tell me where I can get a capacitor for my Candy Condenser dryer model GOC218-80
http://www.buy-spares.ie/candy/tumble-dryer/catalogue.pl?shop=candy&path=111515
Jun 30, 2015 | Candy Dryers
Candy DC218. When I take my finger off the start button it doesn't work!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Candy CDC266 Dryer
CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Apr 25, 2009 | Candy Dryers
Screeching Drum
My machine did exactly the same thing until the belt snapped - and it's a very painful noise!! I'm about to replace my belt and if this solves the problem I'll let you know.
Dec 15, 2008 | Candy CDC266 Dryer
Replacing belt on candy cdc266 reverse action dryer
i have i candy cdc 266 reverse action tumble dryer and the condenser has gone on it
Sep 07, 2008 | Candy CDC266 Dryer
Dryers Logo
188 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
