Question about Intel DG965WH Motherboard
Please help I downloaded the drivers as well as the BIOS from the Intel website--I assumed that they self extracted. I enabled the on board audio, rebooted without any audio now. How do I know that my new bios is in effect? new drivers?
  • Anne Glaser
    Anne Glaser Mar 30, 2008
    What is south bridge?
    Genius:
  • 1,027 Answers
Run everest home it will show under the bios tab the bios version etc.
Check on south bridge to see if the codec is sigma tel if it is download sigma tel audio from that link I gave you
Posted on Mar 30, 2008
  • Anonymous Mar 30, 2008
    When you run everest home
    click on the + sign by the motherboard in left column
    click on chip set in left column under motherboard
    click on south bridge in main right column
    when the south bridge chip set is clicked on then the south bridge or better known as AUDIO CHIP SET AND AUDIO CONTROLER
    are displayed
SOURCE:
Audio driver not found
Hi ,
Go to the site
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
and download your motherboard drivers.
May 10, 2011 | Intel DG31PR Motherboard
My mother board is 82801 problem is no audio device
There could be a problem with the actual audio circuit (which is built in I believe, not sure) on the motherboard itself or the audio has been disabled in the Bios. Reboot your computer and access the bios software and check to see if it has been disabled. If so, enable it and save changes and exit. If not, the chip itself could be defective, you could simply buy a third party audio card and install it in an open slot on your motherboard.Follow the manufacturers installation instructions and Install the drivers that came with your card, (after booting up your OS), and that should take care of your problem. Good Luck!!
Jan 05, 2011 | Intel Motherboard
Hi I have i7 920 on Dx58so and win7. Installed last chipset driver and HDRealteck from "downloadcenter.intel" and updated bios too. In my windows lost the audio device for enabeling and don`t open my...
if you updated bios, you may want to see if all bios settings are correct. i have seen bios updates disable the on board audio. verify that is working correctly (re-enable if necessary) and see where that takes you.
Aug 07, 2010 | Intel DX58SO Motherboard
Hi , I tried to installed many drivers for my
Try upgrading the motherboard BIOS to the most current version. You can download the bios from the ASUS website. If you have not done so, also download the most current audio drivers from the same place. (I assume you have already done this but if not, you should).
Update the BIOS first. Then, install the most recent audio drivers.
Mar 06, 2010 | Computers & Internet
AUDIO SHOWS NO ACTIVE CONTROL DEVICE FOUND
down load audio driver from realtek web site - realtek 97 audio
Dec 04, 2009 | Intel DG31PR Motherboard
No sound
Sometimes the on-board audio is turned off in BIOS by default. Reboot, enter setup and see if it is enabled. If not turn it on, and it then should be in device manager. Also, go to intel's website, and download the latest drivers for your motherboard for the audio (and the rest for that matter) once it shows up.
Jun 29, 2009 | Intel D945GCCR Motherboard
Realtek audio driver 5.10.0.5423 installation problem on my pc
Hi There,
Go to the Intel website, ...
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2766&lang=eng
Select your operating system, and download the audio driver for your device.
Before you install it, restart your pc ,Log into the Bios, make sure that your onboards audio is enabled might say onboard AC97.....
Then go and install you driver for the device, Hope that helped you, IOf not let me know
Regards
techmor
May 28, 2009 | Intel D945GCCR Motherboard
Audio Driver is not installing?
The error you got means the device driver cannot initialize certain ports on your audio device. It normally indicates an incorrect driver. PCs/Laptops normally come bundled with drivers but on rare cases, they will have some compability issues with OS service packs/upgrades. I suggest you follow these steps:
First, you must be sure that your chipset drivers are the later one, otherwise download it from Intel Website directly.
1. Completely remove all your previously installed audio device drivers.
2. Restart your computer
3. Download the correct audio driver for your system.
In your case its a SIGMATEL Audio Controller 9750.
Try to get it from their website, instead of using the bundled driver
4. Install the audio driver
Nov 14, 2008 | Dell Inspiron 8500 Notebook
Audio device is not working
I have been working on this for months and finally got everything including front audio panel going. First Download the latest realtek audio drivers available  from intel's website or go here and download #3 http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows%2A+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21. Next goto control panel and add/remove programs then look for realtek audio drivers that have been previously installed. Remove program if one is found. Then go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+" in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at [email protected]
Jun 22, 2008 | Intel DG31PR Motherboard
Intel DG965WH Motherboard Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
