Question about Sears Exercise & Fitness
Removing the front roller on a pro-form 575TL
Removing the front roller on a pro-form 575T, the rubber sleeve has slid to the right and is rubbing the frame
    President:
  • Sears Master
  • 832 Answers
That sleeve has had it replacing the the front roller will cost you $102.95 plus S/H and tax or got to Treadmill Doctor and they can replace the sleeve for 49.95 plus S/H and Tax and final option you can order the kit for 29.95 Plus S/H and tax and do it yourself. they can be reached @ 1-800-750-4766
Posted on May 15, 2010
What is an doctor blade?
On the Panasonic UF 790, it physically regulates the amount of toner on the magnetic roller by using pressure from its silicon rubber blade rubbing against the magnetic roller sleeve. This friction also helps statically charge the toner so that an even layer of toner is on the magnetic roller sleeve.8a7hwohg2lqqaaaaaasuvork5cyii=
Nov 27, 2011 | Panasonic Office Equipment & Supplies
My pro form treadmill was stuck in the incline position. Now it is down but the belt won't run
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_7_47_47_pm.gif11_13_2011_7_48_35_pm.gif
Nov 13, 2011 | Exercise & Fitness
I had paperjams and i pulled out the paper from the front of the printer. I have done this more than once. I then found out recently that it was best to remove the back and pull ot the paper. Could...
I always recommend that paper jams be removed in the direction the paper would normally travel. Forcibly removing jams generally will not damage rollers, as the hardware tend to cause paper to tear before anything breaks. Removing paper jams in the wrong direction however can break one-way "finger" paper path sensors occasionally. If you are not experiencing a jam every single print, you are probably in good shape.
As for cleaning the rollers, if you have taken the rear door off the printer you are halfway there. You should be able to turn the rollers in one direction or the other by hand. There are plenty of products out there to clean rubber rollers (I use Blow-Off Rubber rejuvenator) but rubbing alcohol on a cloth can work as well. Turn the rollers to get at the entirety of them and scrub along the length with an alcohol dampened rag.
Jun 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
With my canon mf4350d, every page comes out crooked. how do i fix this?
Have your service technician clean your rubber rollers. If you have the technical knowledge and tools to dismantle the entire machine and remove all the rubber rollers, completely clean each one by rubbing them off with a lint-free towel, using either rubbing alcohol or a cleaning solution that is not abrasive, wipe clean (until no more black ink residue can be removed,) and reinstall the rollers.
Nov 16, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
Treadmill front roller has a rubber sleever that keep moving
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
May 07, 2010 | RTO Image 15.0R Treadmill Walking Belt
Installing endcap assembly on a pro form treadmill#585tl getting proper tension on the rear roller right bolt(with spring) to take slack out of belt for proper adjustment. I can't tighten the bolt...
Well congratulations for having gotten that far! The spring on the right hand side needs to be on the rear of the bolt. Be sure it is not in front of the roller or it will only tighten a certain amount. The bolt goes into the roller first, then the washer then the spring/sleeve then another washer and then the nut on the end. If you need a diagram you can go to iconservice.com and search for pftl4206 that should be your model and go to the parts listing in the rear of the book for the diagram.
Good Luck!
Tim
Jan 17, 2010 | Proform Crosswalk 500 Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
When riding 2005 fuel injected harley road king, engine pops, backfires, and idles fast, why?
Sounds like the intake manifold is leaking. The area where the leak usually happens, are those two rubber sleeves that go from the heads, (Cylinder heads) to the intake. Sometimes the clamp/s loosen up. Sometimes these rubber sleeves deteriorate, and cracks form.
This makes the engine backfire, pop, and idle fast.
The added air at the wrong time cause a backfire, when you let off the throttle. The added air causes the engine to pop, because the exhaust valve has sucked up some cold air.
The engine idles fast, because more air is being introduced, and not metered by the injection system.
(The exhaust valve thing. Exhaust valves are supposed to open, and let exhaust out right? Well there is a thing called Valve Overlap.
The Exhaust valve hasn't closed all the way yet, and the Intake valve is opening.
The 4 stroke engine, (Of which a Harley is), has these four strokes.
1.Intake Stroke. Fuel/air is sucked in.
2.Compression Stroke. The piston comes up and squeezes the fuel/air mixture.
3.Combustion Stroke. The spark plug lights the fuel/air mixture off.
4.Exhaust Stroke. The spent gases are expelled out.
Your Road King has one camshaft. There are four cam lobes on it.
Intake, Exhaust, Intake, Exhaust.
If you had the camshaft in your hand, and had the gear end facing you, look down the camshaft. You will see those egg shaped cam lobes. You will notice that No.1 cylinder Intake lobe is facing to the left.
No.1 Exhaust is facing to the right.
If you put a degree wheel on the gear end of the camshaft, and had the No.1 Exhaust lobe ramp nose facing straight up, you would see that it's about 110 degrees, before the Intake lobe ramp at .050 lift, comes into play. (The roller, of your roller lifter has raised the Exhaust valve up .050 inch) There is about 55 degrees before the Exhaust valve hasn't quite shut.
This is okay for normal running. Introduce a vacuum leak, and the surge of extra cold air, makes it pop.
Solution? I suggest checking to see if the clamps on those rubber sleeves are loose. You can also spray WD-40 towards the ends of each rubber sleeve, when the engine is idling, and see if it speeds up. Means, one or more, of those rubber sleeves has deteriorated.
Apr 25, 2009 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Dell 1600N printer paper jam
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Mar 16, 2008 | Dell 1600n All-In-One Laser Printer
Exercise & Fitness Logo
202 people viewed this question
Top Sears Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Sears Exercise and Fitnes Expert? Answer questions, earn points and help others
