Question about Uniden PRO538W 40-Channels Base CB Radio
My Uniden pro538w is very soft when transmitting, Is there a way to increase mic gain with this radio. I have tried three different mics. all sound like your whispering
  • 29 Answers
Hello Drew
looks like you may have to take this radio in for an alignment. It is to new to to much info on the web yet but sounds like the limiter in it s set to tight and may not be giving you full legal audio.
Ray
Posted on Aug 23, 2010
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
R/sig meter spikes on my uniden pro538w cb when keying mic
Does the radio put out and receive? And this could be as simple as your SWR switch isn't in the right position. But if your radio seems to work fine then I wouldn't worry to much about the meter it could be out of line I've seen that many times even on new radios.
Jul 15, 2012 | Uniden PRO538W CB Radio, cb radio 40...
I just bought a cobra 18 wx st 40-channel base cb radio and when i talk in the mic it comes out all distorted on the other end ive tryed three different mics do you have any answeres
Well, someone could have over modulated it. Some trashy techs will cut resistors and do nothing more than make it sound icky and bleed all over. You can turn the mic gain a quarter way to the left from where you had it and see how that performs. A mic gain turned up all the way is OK for farther transitions but a mic gain turned up all the way to people much closer will sequel and sound what I call "mashed out" ( distorted. ) If this does not help then take it to a licensed tech to inspect as the fix will be from inside the radio. Also make sure your SWR is 1-1:5 and no higher than 2. You can loose distance from a high SWR and burn up your radio. Good luck.
Feb 04, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My grant has good mod on sideband but when i transmit on am i get a squeel like sound coming in with my voice but the squeel is louder then my voice. could it be a bad shield on my hand held astic power...
If you have talk back, that most likely why you have feed back. If its on a switch, turn it off. When it was put in, it was done too loud. You can also turn down the gain on the mic.
Dec 21, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
The power is on, however, when I use the mic and speak the "needle" doesn't move, I have tried different mics. Also, the sound coming from the radio is also very soft.
When you say the sound coming from the radio is very soft, are you talking about talk back? if so, you want that soft. If you are talking about reception then just get an external speaker.
If the radio is working, and transmitting ok, the meter is not important.
You may want to get an external meter to make sure SWR's are good.
If it is not transmitting at all, there could be a real problem and the radio needs a tech.
Aug 14, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
No audio Transmit
Try a hand mic with the set, there may be a short within the radio.If not your problem is with the audio amp in the radio itself.Repair should be about $15.00.
Aug 07, 2009 | Cobra 29 LTD CB Radio
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Mic hum
Yes, the wiring is different. Reverse the wires on pins 1 & 2, then reverse the wires on pins 3 & 4.
The wiring for you radio's mike is:
1- Audio
2-Ground (Shield)
3-Receive
4-Transmit
Depending on the vintage of your mike, the colors Uniden uses for these functions are white or yellow for audio, red is transmit & black is receive.
Jul 31, 2008 | Superstar SS-121 120-Channels Base CB...
Uniden PRO538W 40-Channels Base CB Radio Logo
140 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
