Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My 25 hp vtek engine is leaking oil badly from the area in front of the oil filter mount not from the oil filter as this is new but in the general area in front of the oil filter location .I have cleaned away the oil leakage residue and can see the oil running down the side of the block when the engine is running.
  • lesandrichar May 15, 2010
    thnks for the insight I suspected the reason but small engines are not my forte
    Guru:
  • 1,051 Answers
You need to replace the head gasket. It's not a difficult job but will require a torque wrench and you'll need to find the torque settings (foot pounds) for the head bolts. You can get these from a small engine repair manual at a local library or your nearest repair facility may give you the settings.
Posted on May 15, 2010
I'm leaking oil and finally all of it leaked out and where is it leaking from
Obviously a very big leak.
It isn't a good plan to allow oil to leak out until there is none left. Engines are costly, far more costly than oil and you are risking your engine by not checking the oil level and topping up as often as necessary.
The general area of such a large leak should be fairly obvious and in many cases the exact source of a major leak will be obvious.
Unusual for a bad oil leak to suddenly start unless something else has gone wrong, such as a burst oil filter or a blocked crankcase breather.
Apr 22, 2016 | Cars & Trucks
How to change a fuel filter on a polo vivo 2010
Engine oil: Drain or extract and replenish; renew oil filter Engine oil: Drain or extract engine oil ? Chapter. Renewing oil filter ? Chapter. Replenishing engine oil ? Chapter. Draining or extracting engine oil Special tools and workshop equipment required t Used oil collection and extraction unit -V.A.G 1782- t Oil spill cloth -VAS 6204/1- Draining or extracting engine oil Carry out the following procedure: > Note
t For engines with standing oil filter the oil filter must be renewed before changing the engine oil. When removing the filter element a valve is opened, the oil in the filter housing automatically flows into crankcase. t If the engine oil is drained and not extracted with an oil extractor, replace drain plug. This prevents leaks. t Observe disposal regulations! - Extract engine oil using used oil collection and extraction unit -V.A.G 1782-. or - Remove oil drain plug. - Let engine oil drain. > Note
t The oil drain plug is fitted with a secure seal, therefore the oil drain plug must always be renewed. t Observe disposal regulations! - Screw in new oil drain plug with seal hand-tight. - Replenish engine oil, specification ? Chapter. Engine oil capacity: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. Specified torques for oil drain plug: t Petrol and diesel engines 30 Nm > WARNING
t Torque specifications must not be exceeded. t Excess torque can cause leaks in the area of the oil drain plug or even damage. Renewing oil filter Renewing oil filter, 1.4 l and 1.6 l injection engines > Note
t Prevent engine oil from dripping onto components in engine compartment. t Oil new O-rings before installing. t Observe disposal regulations! Renewing oil filter, 1.4 land 1.6 l engine Carry out the following procedure: alt="W00-10211"> - Unscrew cover cap -1- with socket insert 36 mm AF and remove cover with oil filter insert -4- and valve -5-. - Renew O-ring -2- of cover cap and O-ring -3- of valve. - Renew used oil filter element with new filter element. > Note
Observe disposal regulations! - Tighten cover cap -1-. Cover cap torque setting: 25 Nm. Replenishing engine oil Oil specifications ? Chapter Engine oil capacities: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. General notes > Note
Observe disposal regulations! - After replenishing with oil, wait at least 3 minutes and then check oil level. - Pull out dipstick, wipe with a clean cloth and push dipstick in again to limit stop. - Pull dipstick out again and read oil level. alt="N01-10183"> For dipstick as illustrated: A - Oil must not be replenished. B - Oil may be replenished. It may happen that the oil level afterwards is in the -A- region. C - Oil must be replenished. It is sufficient if the oil level is in the -B- region (hatched area) afterwards. There is a danger of damaging the catalytic converter if the oil level is above the -A- marking. - If oil level is below -C- marking, top-up oil to -A- marking. alt="N01-10255">
Mar 14, 2015 | Volkswagen Polo Cars & Trucks
Oil leak
Not sure where your oil pressure sender is on that engine, but usually they are close to the filter. Or perhaps leaning on the top of the engine, like the fill cap, cracked something. Another possibility is a bad gasket on the new oil filter or overfill by 1 quart.
May 19, 2013 | Ford Freestyle Cars & Trucks
Oil leak above the oil filter no one can point the like
Oil leaks can be a pain to locate so I will give you a few tricks I've picked up along the way for locating oil leaks. Start by cleaning/degreasing the area. You want to remove as much of the old residue as possible. Then you can do several things from here.
1. Purchase and oil dye additive (this additive makes the oil glow when a black light i shined on it) and run the engine for a little while then re-inspect with black light to find locations where dye is concentrated.
2. After cleaning, spray the are that you suspect the leak is coming from with a spray on type foot powder(powder sprays on white providing an excellent contrast to trace leak). Run the engine and follow the oil trail to source of leak
Mar 25, 2011 | 2000 Daewoo Leganza
Where is the oil pump located in A 1993 ford thunderbird V6?
Inside the oil pan for the 2.3 and 5.0
  1. Disconnect the negative battery cable.
  2. Remove the oil pan.
  3. Remove the oil pump inlet tube and screen assembly.
  4. Unfasten the oil pump attaching bolts, then remove the oil pump gasket and the intermediate shaft.
To install:
  1. Prime the oil pump by filling the inlet and outlet ports with engine oil and rotating the shaft of pump to distribute it.
  2. Position the intermediate driveshaft into the distributor socket.
  3. Place a new gasket on the pump body and insert the intermediate driveshaft into the pump body.
  4. Install the pump and intermediate shaft as an assembly.
WARNING Do not force the pump if it does not seat readily. The driveshaft may be misaligned with the distributor shaft. To align, rotate the intermediate driveshaft into a new position.
  1. Install and tighten the oil pump attaching screws to:
    2.3L Engine: 12-15 ft. lbs. (16-20 Nm) 5.0L Engine: 22-32 ft. lbs. (30-43 Nm)
  2. Install the oil pan.
  3. Connect the negative battery cable, then start the engine and check for leaks.
On the 3.8...
The oil pump is mounted in the front cover assembly. Oil pan removal is necessary for pick-up tube/screen replacement or service.
  2. Raise and safely support the vehicle on jackstands.
  3. Drain the engine oil, then remove the oil filter.
  4. If necessary, remove the oil cooler.
  5. Unfasten the oil pump-to-front cover retaining bolts, then remove the pump from the front cover.
  6. Lift the two pump gears from their mounting pocket in the front cover.
  7. Clean all gasket mounting surfaces.
  8. Inspect the mounting pocket for wear. If excessive wear is present, complete timing cover assembly replacement is necessary.
  9. Inspect the cover/filter mounting gasket-to-timing cover surface for flatness. Place a straightedge across the flat and check the clearance with a feeler gauge. If the measured clearance exceeds 0.004 in. (0.10mm), replace the cover/filter mount. Replace the pump gears if wear is excessive.
To install:
  1. Lightly pack the gear pocket with petroleum jelly or coat all gear surfaces with Oil Conditioner D9AZ-19579-CA or equivalent, then install the the pump gears in the cover pocket. Make sure the petroleum jelly fills all voids between the gears and pockets.
WARNING Failure to properly coat the oil pump gears may result in failure of the pump to prime when the engine is started.
  1. Position the pump body O-ring seal and install the pump body to the front cover using alignment dowels on the front cover.
  2. Tighten the pump retaining bolts as follows
    1. For vehicles through 1993, tighten the M8 bolts to 18-22 ft. lbs. (25-30 Nm) and the M10 bolts to 30-40 ft. lbs. (40-55 Nm).
    2. For 1994-96 vehicles, tighten the four smaller bolts to 15-22 ft. lbs. (20-30 Nm) and the two larger retaining bolts to 6-11 ft. lbs. (8-15 Nm).
  3. If removed, install the engine oil cooler. Install the oil filter.
  4. Carefully lower the vehicle, then refill the engine crankcase with the correct type and amount of engine oil.
  5. Connect the negative battery cable, then start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2010 | Cars & Trucks
I need to know how to change the oil filter
its fairly simple remove the splash cover if you van has one, and then get an oild filter wrench that fits the filter...loosen with wrench.....twist the rest of the way off....replace filter with new one....DO NOT USE WRENCH TO TIGHTEN FILTER...hand tighten...then go 2/3 of a turn after it snugs up. fill with oil..your done.
Feb 04, 2010 | 1992 Pontiac Trans Sport
Change oil
Set parking brake and use jack stands if you raise the vehicle.
1. Remove engine front undercover.
2. Warm up engine. This is need for the oil to flow freely when draining.
3. With engine stopped loosen oil filler cap and then remove drain plug.
4. Drain oil into a drain pan.
5. Install drain plug with new washer. Tighten to 25 ft-lb.
6. Remove oil filter using a filter wrench.
7. Make sure the surface is free of foreign materials.
8. Apply engine oil to the seal and install your new Nissan filter. Tighten filter 2/3 turn after contact with surface or 13 ft-lb.
9. Refill engine with 6 quarts of oil.
10. Start engine and check for leaks.
11. Stop engine and check oil level and add to the full line.
12. Reinstall engine front undercover.
Dec 20, 2009 | 2004 Nissan Armada
HAVE A OIL LEAK COMING FROM ABOVE THE OIL FILTER.
Has the oil filter just been replaced? Sometimes the old gasket sticks to the mounting area, causing leakage if the new filter is installed on top of it. It is also possible the gasket was for some reason missing on a new filter. Let me know if this is not the cause, I'll try to help further.
Dec 16, 2009 | 1991 Honda Accord
Oil leaking on front right side of the car near oil pan and oil filter
You need to clean the engine and then run the vehicle while watching the area. The most common failure is the oil sending unit located near the oil filter. I have also seen a leak develop between the oil pump housing, which is mounted directly behind the hamonic balencer and the engine block.
Aug 14, 2008 | 1998 Buick LeSabre
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
326 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
