Question about Pioneer DEH-P4700MP CD/MP3/WMA/WAV Receiver
Power wire (red) came out of the plug. I need to know where it goes
  • 311 Answers
It goes to 12V battery
Posted on May 15, 2010
Need to know how to connect power cord with four wires...
this should be a 30 amp 4 wire plug for a dryer white to center take off the ground strap from the center white post that bolts to the green ground screw u want to isolate the ground green wire goes to green ground screw, black and red goes to outside screws one left one right
Apr 22, 2013 | Dryers
I need to re solder the power supply plug to the board. Don't know which chord goes where( red and black) . It's a Presonus firestudio 2626. Thanks!
Get a digital meter and check the other end of the plug that fits into that jack. With it plugged in, you hold one lead from the meter to the barrel of the jack and touch the other lead to the tip. The meter will show a value if that value has a -- infront of it then the leads are reversed. If there is no negative sign then it is ok. Then you wire the board wires back on to the corresponding location on the jack.
Mar 02, 2013 | Audio Players & Recorders
I JUST PURCHASED THIS AMP AND THERE IS NO WIRING DIGRAM WIYH IT.I NEED TO KNOW HOW TO WIRE THE POWER THERE ARE THREE WIRES RED,BLACK AND BLUE
Red goes to your battery, black gets grounded to the vehicle frame, and the blue wire is the remote turn on wire from the radio. There should be 3 power terminals together. The red wire goes to power or (+), the black wire goes to GRD or (-), and the blue wire goes to remote (usually between both the power and ground terminals). hope this helps
Aug 26, 2011 | Car Audio & Video
I need to wire an electric brake controller in my truck
you can either wire it straight or gm makes a connector that plugs into the drivers side floor . theres a box down there that has a cover over it and the gm connector plugs straight to it. but be careful because i have seen several times were gm wired it wrong the stop light plug is in the wrong spot.take a test light to ground touch each connector while pressing and releasing brake pedal the one that lights the light, is your stop light look on there connector and check to see if that plug is going to the red wire if not move the red wire to that spot. as for wiring it you have to do it this way. black wire goes to constent hot, white wire goes to constent ground , blue wire goes back to your trailer plug for your electric brake, and red wire as you know by now goes to the stop light.
Dec 27, 2009 | 2004 Chevrolet Silverado
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Missing a wire off the alternator plug. only has 1 wire in the plug?I don't know where the other wire goes? It is mising completely?
There is a big red wire the power wire goes on the big post and the other two goes in the terminal which plugs into the end of the alternator. If one is already there then the other one goes next to it. It must have come out of the terminal.
Jul 02, 2009 | 1989 Chevrolet C/K 3500
I don't know how to re-install loose wires on my power cable
Goes in this order:
Red
White
Yellow
leave last 1 blank
Apr 25, 2009 | Computers & Internet
Wires pulled out of the plug and I don't know which one goes wher
you might need to buy a new plug, try this site
http://www.onlinevacuumparts.com/ps-328-7-ge-6850-106766-canister-power-nozzle-parts.aspx
Jan 09, 2009 | GE 106766 Bagged Canister Vacuum
Im trying to get my nintendo 64 to work on my avic d3. i know i need a power inverter, what else do i need? also, do you know where the red white and yellow plugs from the nintendo 64 goes into the d3?
the red white yellow wires plug into the rear of the unit (white and red RCA will go into video or aux input) the yellow wire will go into video in (the red and white RCA from Nintendo they can go into either video 1input or aux input) on back of in-dash unit
hope this helped
Dec 15, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Pioneer DEH-P4700MP CD/MP3/WMA/WAV Receiver Logo
55 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
