Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jams in printer
When printing a document, the paper jammed in the printer. I managed to free the paper but when copying the next docuent, it jammed again.
  • 4,041 Answers
Hello there There may be a small bit inside still.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 16, 2010
Why does my printer produce a paper jam when printing from laptop but does not jam when copying
When you order a print from the laptop, it gets the paper from the paper tray. When you copy, the paper has a slightly different path it follows to deliver your printed result. Try to put the document in the tray with the blank pages and see if it also jams! Let me know what you find out!!
Sep 28, 2014 | Office Equipment & Supplies
Canon pixma mp287
Canon pixma keeps jamming
Dec 20, 2013 | Office Equipment & Supplies
While copying mode, and paper feeding into printer, the sheet was pulled to remove and it jammed causing an error message to be generated. (Contact Epsom support). After restarting printer, print comes out...
To clean your Epson Stylus > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
This will solve the paper jamming problem. Hope this helps, please rate if the solution was helpful, thanks!
Sep 02, 2011 | Epson Stylus CX6000 All-In-One InkJet...
There is a document jam 1. After I remove the paper and code goes away, the printer may print a page or two and then jam again. I have tried a new pack of paper (fanning it) I have tried a new...
You refer to a document jam then you mention fanning new paper but that refers to a paper jam.Which one is the problem? What does the screen say? If document jam then its your originals you are copying. If paper jam then its the paper in the machine. I cant help you any more because your do not state the make or model. Please repost with a lot more detail. Cheers
May 16, 2011 | Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
