Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
I am not getting any water, I have changed to filter but still no water. i also check the water line , it's working. i also blew high pressured air thru the line to see if there is blockage, but no water. help!
  • 6,784 Answers
HI. The inlet valve assembly will be the culprit, here.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink or at the rear of your unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on May 15, 2010
  • 29 more comments
  • talessib May 15, 2010
    water inlet valve were do you find this, do I have to take off the panel in the back
  • Michael Masters
    Michael Masters May 15, 2010
    If you would kindly post the entire model number, i will post a link to the necessary diagrams to help with this inspection. The valve is usually mounted on a bracket on the lower rear section of your unit. just follow the water lines from the wall to the refrigerator valve section on the backside.
  • Michael Masters
    Most units of this nature will have the inlet valve exposed, but in your case, a panel may need to be removed to expose the entire valve for extraction...
    Please post the model number of the unit, asap.
    Thanks..
    mf d2561heb sin 10801406gj
  • Michael Masters
    Thank you, one moment please...
  • Michael Masters
    Thank you for your patience. Ok, CLICK HERE to be directed to the diagram of the rear section of the cabinet. The affected apart you will be looking for is labeled number 10 on the diagram provided. The access panel that you will need to remove will be labeled number 1.
  • Michael Masters
    The valve cover plate will be labeled number 2 on the diagram. The valve assembly will be directly behind the valve cover plate.
  • Michael Masters
    I don't think it is unnecessary for the main concealment plate, on the compressor side, to be removed. i think you should be able to access the valve by just removing the valve access plate. it is much smaller.
    water inlet valve the connection are fine , now what
    Inspect the filter screen where the supply line connects: where is this/ on the diagram
  • Michael Masters
    The filter screens are a integrate part of the valve assembly. once you have pulled the lines always from the valve, look into the section of the valve where the lines go. This is where the filter screens are located. make sure there are no calcium build up in this area. you can take a toothbrush and clean this area, if needed. if the screens are clear, move on to the electrical testing procedure i have typed, above.
    what # is it on the diagram
  • Michael Masters
    The filter screens are not labeled on the diagram, due to the fact that, they are not an external part. These screens are integrated into the dual valve assembly, which is one whole piece.
    integrate part of the valve assembly: # is this
  • Michael Masters
    The screens are inside each valve opening. you will need to look into each valve opening(where the lines are fitted) to inspect for clogs.
  • Michael Masters
    number 10
    Do I just pull the water line out or do I use a screw driver to pry it away from the assembly
    it's plastic I don't want to break it
  • Michael Masters
    These plastic lines just fit in the orifice. gently push and turn, slightly, while pulling after the slight turn to the left or right. It is not threaded or clipped.
    okay the filter not blocked, Now what
  • Michael Masters
    There should be a connector on this unit that will need to be loosed to free the line. turn counter clockwise to release. all models differ, unfortunately.
  • Michael Masters
    OK, now you will need to test the valve. I have posted the entire testing procedure above. follow carefully. you will need a multimeter in order to perform this necessary test.
    okay that is fine, could there be a block by the filter connection inside the fridge
  • Michael Masters
    When did you install this filter? It may have reached its operational time limit. When this occurs, the filter will stop all water flow to the dispenser and ice maker, as well. Check all lines to and from the ice maker and dispenser. if they are dry, the filter may be the culprit.
  • Michael Masters
    If the filter is quite new, it may not be installed correctly, or there may be a blockage at the filter feed.
    anyting?
  • Michael Masters
    By the way, what were the valve reading on both valves?
  • Michael Masters
    There are two terminals on each valve. Both valve solenoids should read evenly(200 to 500 ohms). if one valve solenoid read lower than the other, this dose not constitute a working valve. Actually, any valve assembly that reads 250 or below should be replaced. Just a side note here....
  • talessib May 16, 2010
    so if they were 250 then replace them? where can I get the part?
  • Michael Masters
    Michael Masters May 16, 2010
    The 200 or 250 mark is the bare minimum rating. it shows a weak solenoid structure. a good strong reading should be in the 300 to 500 reading range. This particular valve can be purchased at the link below.
    CLICK HERE
    Quick question:
    When attempting to retrieve water from the dispenser, do you hear any clicking at the solenoids at the valve, or at the back side of the dispenser, by any chance?
    Are all the lines completely dry inside the unit?
  • Michael Masters
    Is the ice maker receiving water correctly?
Diesel wont start engine
Diesel has to have high pressure fuel. Water is very bad, air pocket in pressure fuel line very bad, engine glow plugs bad. Pretty much covers your problem, from your question, so with that said check your filter (usually glass) for water if present this has to me all bled off and filter either cleaned or replaced, also if you have a air pocket this has to be bled out and there is a spot on your engine that will allow this, it is on the high pressure side that has a bleeder screw, plug, Etc. call dealer for location and try yourself, about all I can help here, but in you asking question makes me say this is high pressure and caution is in high priority as the bleeding fuel can inject itself into your skin, so be careful.
Jul 21, 2014 | Boating
The small nylon air line that goes to the pressure switch blew a hole in it. I replaced the line and it blew a hole in it also. the line is getting very hot which is probaly the reason-----but why is it...
You need to change the pressure dial. There is too much pressure going down the line, that's why it gets hot and blows the hole. Check what psi it's rated for, and adjust it back to that. The pressure dial is usually on the pressure regulator just before the hose connects.
Jul 18, 2011 | Air Tools & Compressors
I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
My 2004 F150 supercrew 4x4 AC blowing warm air
I can give you a few tips on this but you need to check the specifics for your low and high A/C pressure switches. The 45 sounds slightly high.
What you want is to have your A/C compressor running steady for maximum cooling. This means the charge pressure is moderate and it keeps the pressure cut-off switches from deactivating the compressor clutch the longest. The pressure is high enough to keep the low pressure switch from activating and low enough to keep the high pressure switch from activating.
These switches can usually be changed without losing Freon. The spring resistance can weaken, changing when the switches work.
There is a difference in the Freon oil charge for different makers. This can affect performance and durability. The filters you mention are often contaminated when the system is open through complete Freon loss.
Another way of looking at this is a 45 psi is suppose to be Freon. All is good when it is pure, but if contaminated with ordinary atmospheric air, it can not work as good or even at all.
There are some other products you can use to clean the coils and such. A foaming product is sold at stores like Lowes or Home Depot. Theory is it works like shaving cream, expanding in the fins and pulling dirt out. You then flush with water. Check label warnings for use on different metals.
Find out when the cut-out switches are suppose to activate and what your recommended switch thresholds are. Hope this helps.
Aug 12, 2017 | 2004 Ford F150
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
After changing the filter the ice maker would not work.
It needs to get the air out of the line before the water will fill the tray. When the line is opened up air will get inside and needs to bleed out first. On units with a water dispenser it is good to run it after a filter change to make the ice maker usable faster. An ice maker times the water for a fill not the amount of water since it uses a pressure regulator, so it does not know there is air in the line.
Sep 29, 2009 | Kenmore 57029 Side by Side Refrigerator
SMALL OUTDOOR BEER REFRIGERATOR DOOR LEFT OPEN OVERNIGHT IT STARTED DEFROSOTNG AND THEN ACTED LIKE IT BULIT UP PRESSURE AND BLEW OUT AIR OR REFRIGERANT AND DOES NOT COOL ANYMORE
Hi, absolutely there's refrigerant (freon) leak check your condenser and evap. for rupture (broken lines) also check for oil, presence of oil means, refrigerant (freon) leak, plug ref, and listen, for hissing sound inside and outside of ref. try to locate leak, or call mechanic, repair leak, change filter drier and recharge, if your evap punctured, you should immediately disconnect ref, and dry all water from evap, prevent water from entering system, could damage compressor, or if water get into compressor, you will have to change compressor oil. yes, you surely have a refrigerant (freon) leak.good luck.
Aug 12, 2009 | Refrigerators
No cold water
  1. Make sure filter is installed right.
  2. Disconnect water line see if water is flowing from line. May have a water valve in line not working.
  3. reconnect line but leave lose open inline valve just a little see if water flows out. No water PSI may be to low to reach up to fridge or valve stuck closed.
  4. Got water to connection tighten check dispenser for water.
  5. No Water If your system has a reservoir to store & chill water Your float may be stuck locate & check unstick if needed.
  6. Still no water May have faulty dispense value. Check value replace if needed.
Please rate hope this helped. If I can help further I'll standby.
Mar 09, 2009 | Samsung RS2534 Side by Side Refrigerator
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
115 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
