Question about Timex 1440 Nylon watch
Timex 1440 sports WR50M
The buttons on my watch don't seem to correspond to any instructions which I can find. I have a Mode, Start/Stop, Adjust and Indiglow buttons. All I want to do is set the right time. Should it be this hard?
  • 3 more comments
  • Just Tryin May 15, 2008
    Solution # 1 is by far the best solution. I was able to set my 1440!!!! Thank you "Guest". THANK YOU!!!! IT WORKED when all other directions failed.
  • njwitch Jun 12, 2008
    The picture in the direction are for the w-212 and definitely don't match the 1440. I can't figure out which button is which except obviously for the light on the lower left side. Does it have a choice of 12 or 24 hour ability?
  • stanton64 Jul 17, 2008
    i am unable to set the time on my 1440.
    date is correct as well a al other functions.
    an you help?
    thanks,
    w.s.a
  • Anonymous Mar 15, 2014
    How to turn off alarm on 1440 WR50M sports watch I have looked everywhere none of them would work I have 4 buttons indigo bottom right mode bottom left star stop top left and set top right
  • 3 Answers
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Posted on May 15, 2008
  • 3 Answers
Setting the Timex 1440 Sports WR50MT5G891:
  • This model (WR50M) has four buttons, from left to right, top to bottom: 1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
  • To set or change the time:
  • Press and hold Set and Start/Stop simultaneously; the seconds will start to blink
  • Release both buttons
  • Use Mode button to toggle through to Hours, Minutes, etc.
  • When desired number (such as Hours/Minutes) starts to blink, use Start/Stop button to change number
  • When done, hit Set
Posted on Aug 01, 2009
You may also want to try holding the LAP/RST button until you see the digital read-out say "SET". From there, you can use the mode button to alternate through different settings and you use the ST./STOP button to change the settings. From my experience different products have different ways to be set and Timex does a poor job of making that known, if none of these solutions work for you, you might also try different things, just takes some playing and a little bit of time.
Posted on May 12, 2008
HOW do I change my wr50m watch from army time to regular time??????
Posted on Nov 24, 2009
I have just bought mine. Maybe this will help. Keep pressing the Indiglo button for about 3 seconds, then you will see the numbers blinking. Set the numbers using the Start/Stop button, go to the next set of number by using the Split/Reset button. And after you're happy with the setting, click the Indiglo button again, and you're done.
Posted on Apr 03, 2008
This wr50m sports watch has four buttons top to bottom left to right 1.set 2.start/stop 3. mode 4.indiglo 1.hold set for 2 seconds until seconds digits flash 2.press start/stop this will set seconds to zero choose the correct seconds 3.press mode until hour digits flash press start/stop to choose the correct hour 4.press mode until minutes flash press start/stop to choose the correct minute 5.press set key again when your done and press mode key until you go back
Posted on Apr 20, 2011
Okay. I was looking for a solution to this problem as well. My 1440 Sports is a few years old now, and, of course, I don't have the manual. Anyway, here's what to do: Hold in the Mode button until the alarm time appears. Tap the Mode button again, and the time should appear with the seconds flashing. Use St/Stop to choose among seconds, hours, and minutes, and use Lap/Reset to increase the selected number. Use Mode to put the thing back in regular operational mode.
Good luck.
Posted on May 13, 2008
  • Jordanb1211 Nov 21, 2011
    Amazing. Thank you. That worked.
I have the same problem. My buttons are Mode, Start/Stop, Set and Indiglow. The pictures on the directions that came with the watch have the buttons in different positions. In addition my buttons don't do what the direction buttons say they will do. No button combination I've found will change the time. HELP - otherwise I'm returning it to the store.
Posted on Mar 31, 2008
I have figured out how to set time on the Timex 1400 Sport, now I'm having trouble setting the time
Posted on Jun 16, 2008
Omg thanx so much!!!!
this rly helped
luv all u hot guyz
*Stacey*
Posted on Nov 07, 2010
Trying to set time on Timex 1440 sport with mode button top left, start/stop upper right,adjust bottom right,indiglo bottom left..no instructions match or work.
press and hold the mode button until the digits blinks then press it again once, (digit that are blinking is changeable) use the "start/stop button to choose what will you change and adjust buttton to adjust it. if your done, press the mode button again once.
i hope i had been helped you.
Aug 10, 2011 | Timex Watches
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
How do i set the time for my adidas ADP6002?
The watch looks and feel great; the band doesn't hurt my wrist like other watches. The instruction book, however, was awful. It was a bunch of instructions for other watches, not the ADP6002. It took a few minutes of playing around for me to figure out how to set the watch. Here's how to do it: 1) Make sure there is a little "t1" above the second hand. If there is a "t2" instead, hold the Start/Stop button for 3 seconds. (This is the part that was messing me up) 2) Hold the Set/Light button for a few seconds. The watch should say LIGHT and "OFF" or "ON" should be flashing. 3) Press the Mode button until the hour hand starts flashing. You can adjust it up and down by the Start/Stop and Lap/Reset buttons. 4) Press Mode to adjust the minute, second, and other settings. 5) Press Set/Light button when you are finished.
Jan 04, 2011 | Adidas Digi III Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
The Water Star came with no instructions. How do we set the time?
Look at the face of the watch. It should read in very small print which button operates the mode button. Pressing it should change or flash the time, while it flashes, press the button that corresponds with the Start/Stop button to change the hour, press the button marking reset should go to the minutes and so on, when finished press the mode button again.
Sep 13, 2008 | Bulova Watches
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 | Watches
Kenneth Cole KC3081
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Timex 1440 Nylon watch Logo
6,345 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Pieter Vleeshouwers
Are you a Timex Watch Expert? Answer questions, earn points and help others
