Question about Culligan Under Sink Water Filter
Where can I get a manual for Culligan Aqua Cleer?
  • Anonymous Mar 31, 2014
    culligan aqua cleer
I found the manual for an Aqua Clear AC15 at the following web site. Go to the below web site and locate the filters for your system. There will be a link to the manual in a .pdf format.
http://www.freshwatersystems.com/s-69-culligan-water-filters.aspx
Posted on Nov 27, 2010
Drain line constantly drips out of my aqua cleer water drinking system
Hi!you can use any wet/dry sealant to put on your dripping line.
Sep 03, 2011 | Home
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Jan 26, 2010 | Culligan Sediment Water Filter
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
Egg smell has returned to culligan iron-cleer unit. unit is draining properly.
Iron cleer and sulfur cleer systems have a bed life of 750000 ppm. This is generally about ten years. You can try running the system every day for 1 week to see if it improves. The air pump may not be working properly so iron and h2s may not be being oxidized properly. H2S smell would be the first symptom of this. I would suggest a service call.
RJ
Nov 09, 2009 | Culligan Sediment Water Filter
Culliagan aqua-cleer drinking water sytem: under sink install
Refer to the below link for the h-30 installation manual.
http://www.freshwatersystems.com/t-manuals.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Mar 08, 2009 | Culligan Under Sink Water Filter
Culligan Under Sink Water Filter Logo
519 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
gbob59
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
