Question about Refrigerators
Ihave a model hss25gfta ww hot point refriderator. I had the power off while working on a light fixture. when I turned the power back on the refrigerator control for the ice box and freezer just blink the lights are on in the door and inside but the refrigerator is not running I have searched the owners manual for a reset proceedure but could not find
    Scholar:
  • 58 Answers
Most like the controls frosted up in the ice box ... empty the freezer and leave the fridge unplugged for a while ... this will allow the frost to disolve ... plug it back in and it should be ok...
Posted on Mar 30, 2008
  • 3,037 Answers
I believe the control board could have gone bad, have you checked it at all? Are you experienced with checking electrical equipment? If not, please have a trained expert open up the fridge and check it. Most likely you will need to replace it. Let me know what you find when you check the board. Is the ice maker going crazy at all? Please post an update. Thank you and Good luck
Control panel lights not working and none of the buttons resond
Power? Has circuit breaker popped? Possible you have ground fault protected outlets and one of them popped like a circuit breaker. It usually causes all outlets on that circuit to also disconnect. They have a reset button similar to other circuit breaker devices, so double check. If it pops again, you may have a serious electrical problem or appliance problem. Unplug all appliances plugin one at a time to discover bad appliance. If none are bad and you still have frig problem. Time to call an electrician. You may be able to verify frig via extension cord from an outlet outside the kitchen. That if lights and buttons work, then you know it's the kitchen circuit problem. If not you may have a major problem with the control panel itself. Time for an appliance technician.
Feb 27, 2015 | Hotpoint Refrigerators
Why wont ceiling lights work after blown fuse when all other sockets/lights in the room work?
If turning on the lights caused such a huge surge of power that it flipped the breaker, it could have been enough current to fry the hot wire (the one electricity flows into the fixture from) leading from the source to the fixture, or to blow the contact point where it connects to the fixture. This is even more likely if the fixture is old and doesn't have a green grounding wire to dissipate excess current, or if your wiring is prone to weakening from age or animals chewing on it.
If this is the case, you should flip the breaker to the off position and call an electrician immediately, since the hot wire will still be live up to the point of the break. A live wire floating around in your ceiling is a major (and I mean major) fire hazard.
Sep 01, 2014 | Home
I have model HSS25GFTA WW, and the freezer is not freezing most of the items in it.
First you'll need to determine whether it's a sealed system issue or failure of some other part. Troubleshooting system problems is beyond the scope of this media. YouTube has literally hundreds of such videos.
Jul 03, 2014 | Hotpoint HSS25GFP Side by Side...
I have a dead short somewhere in the wiring for 6 recessed ceiling lights. How do I trouble shoot this to find the short
Test each light separately.
Black Hot wire arrives at one screw on the switch. The Hot black wire going to Lights connects to other screw on the switch.
The White Neutral that completes the circuit to lights is connected with other white wires that are covered with wire nut pushed to back of box.
Open up light#1, and the Hot and Neutral arrive from switch box.
The Hot and Neutral going to lights#2-6 are also located inside light#1 box.
Check each wire for signs of high heat and burning. Check each wire if the insulation has been sliced, or cut short, or if copper is visible because wire nut does not cover wires correctly
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Disconnect Hot and Neutral going to lights#2-6, so switch is only turning on light#1.
Test if there is a short when turning switch ON.
Then repeat step, so switch turns on light#1 and light#2, but light#3-6 are disconnected.
May 31, 2012 | Electrical Supplies
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Our flourescent kitchen light stopped working...turned the switch on one day, the light came on , then went right out. We wanted to change fixtures anyway so we used this as an opportunity. Purchased new...
If you are showing power at the switches, have you checked at the light fixture itself? You will need to read from the black to the white make sure that you have 120 volts if you do then hook up wires to light fixture and read again. If you no longer read 120 volts then you have what I would think is a lost neutral. That is the white wire. You will then have to do a little back tracking to find where your hot feed is coming from. Check this for now and reply back if you need further help. Good luck!
Oct 03, 2010 | Leviton Decora Light Dimmer Switch
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
