Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Letters & numbers look like used ribbon on typewriter
All of my emails and letters look like the old days of manual typewriter when the ribbon is worn out and the characters down print . I don't know what model of monitor I have it just says Flatron wide in the upper left corner
  • 66 Answers
Your video is failing on the pc. get the model and serial off the pc and I can further help you
Posted on May 15, 2010
When typing the very top of the letter or number is cut off.
First look at the ribbon, be sure that there isn't creased or folded. If the ribbon is old the edges will have have places where it will not print. If everything seems OK there is a ribbon lift adjustment on the front side if the printer just under the ribbon deck. You will need a 9/32 wrench and a skinny flat blade screw driver.
DickyO
Apr 09, 2011 | Lexmark Wheelwriter 3500 Typewriter
I get an ink spear on the letter A. What can I do to fix it?
First remove the P/W rotate it and look at the a spoke it may be bent then clean the type especially letters with small enclosed areas e,a,b,d.&, and like letters. Sometimes as ribbons get old theflake if that is the problem the spear will come off with a slight rub.
DickyO
Mar 22, 2011 | Lexmark Wheelwriter 10 Series II...
I have a smith corona sd680 work processor typewriter. When I type the letter don't come out clear and I have to type over and over in order to read the letters. This is an old typewriter in the office...
This problem is usually caused by an old ribbon theey do dry out when left in tthe typewriter a long time, also if the paper is really hard or has a slick surface the ink from the ribbon will not stick to the paper.
Dec 14, 2010 | Smith Corona Office Equipment & Supplies
Nakajima typewriter model AE830. New ribbon installed. when typing printed letters appear only lightly printed on paper. Any way to adjust?
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
Jun 24, 2010 | Nakajima Office Equipment & Supplies
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Printing different letters
take to a repair shop or get a new one, no easy fix for this
Aug 21, 2008 | Brother GX-6750 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
77 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
