Question about HP Compaq ProLiant DL380 G4 Server
Software Checking for Particular DL380 Processor
I have a DL380 G3 with a 2.8 Processor. Cisco Communications Manager (CallManager) version 6.x and above checks to see if it's particular processor speed (2.4Ghz or 3.06GHz). The software is Linux based.
Would like to see if there is a way of 'fooling' the software to allow the installation to continue.
Any ideas?
    Problem Solver:
  • 17 Answers
If your proc speed is 2.8, then what is the problem? The min speed required is 2.4 GHz right?
Anyways you may try overclocing the processor, however at your own risk as this may cause damage to the server.
http://www.xbitlabs.com/articles/cpu/display/oc-guide.html
http://www.pcguide.com/opt/oc/risksRisksCPU-c.html
Posted on Jul 20, 2008
SOURCE:
How to access Cisco Unified Communications Manager Administration ?
from what I have researched on the web you need to download the Cisco unified Communications Manager software on to the P.C you wish to use to access the server via the web browser. it states you open the software via a web browser. The reason being the Voip server has no software on it.
http://www.cisco.com/web/developer/cucm/content/download.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/CUCM_BK_A09578D7_00_admin-guide-cucm-imp_1151/CUCM_BK_A09578D7_00_admin-guide-for-cucm-1105_chapter_01.html
Apr 20, 2016 | Cisco 7940 IP Phone
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Jun 25, 2014 | Computers & Internet
I have added cisco 7916 expansion module to 7965 cisco phone.Now when i started the phone,phone works but expansion module screen shows cisco logo and lights continuously flash.
I know it may be late (definitely late), but have you defined in the CallManager, that your phone has a "side card"? If CallManager does not know that it has to push an additional firmware to a particular phone, it will not work.
Good luck,
Mike ' CCNP, CCVP, CCSP, CCDP, MCSE, etc.
Headset Adapter Co.
Headset Adapters for office phone system
Mar 21, 2011 | Cisco Systems - Unified IP Phone...
Cisco 2514 does not switch on straight away. It powers on about 1min after switch depressed. it also loses the correct date and time if switched off.
if you issue the command show version
At the bottom written in bold you should the config register settings these nee to be as shown at the bottom of this page
R1#show version
Cisco Internetwork Operating System Software
IOS (tm) 2500 Software (C2500-JS-L), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 06-Jul-00 10:02 by cmong
Image text-base: 0x0306F914, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFT
WARE (fc1)
R1 uptime is 1 day, 5 hours, 39 minutes
System returned to ROM by power-on
System image file is "flash:c2500-js-l.121-3"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 11844920, with hardware revision 00000001
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2102
if yours differs the use the these commands to correct it
R1>en
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#config 0x2102
R1(config)#^Z
R1#
Hope this helps
Mar 15, 2011 | Cisco 2514 Refurbished Router (CSCO2514)
Good day! How Cisco 7911G IP Phone can connect to the Call manager Cisco 7912G IP Phone?
You must have a valid functional callmanager. You then set option 150 in your DHCP which specifies the IP address of the TFTP server which is ultimately callmanager.
Nov 04, 2010 | Cisco 7912G IP Phone
Can Cisco do the equivalant of Nortel DISA
DISA can only be accomplished using Cisco callmanager and it's accompanying product unified contact center expresss.  You would have to build a custom script in contact center express to accomplish this.  If you are interested, please contact me @ [email protected] for further info.
Sep 13, 2010 | Cisco 2821 Integrated Services Router...
My Cisco IP Communicator screen is blank
Is the phones
registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes. http://cisco.com/en/US/docs/voiceipcomm/cucm/admin
/413/ccmsys/a03ptcss.html#wp1020642
If it is CME, then it could be a configuration issue
http://cisco.com/en/US/docs/voiceipcomm/cucme/roadmap/itsph.htm
Jul 16, 2010 | Cisco IP Communicator Full Version for...
I have cisco ip phones 7941 with the correct MAC and Number in the call manager , but the phone will not register
Make sure you have the phone configured as the correct device type in callmanager. Also, try and turn on auto registration in Callmanager as this will allow everything to register. Then go back and put the correct configuration the phone.
Jun 16, 2010 | Cisco 7940 IP Phone
How do you hide the displayed number on Cisco Phone?
You will need to modify the template assigned to that particular phone. Depending on the service you are using (CallManager onsite or hosted VoIP, or other options), you may or may not actually have access to make these changes. See also Cisco's guide located at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Jan 08, 2010 | Cisco 7940 IP Phone
HP Compaq ProLiant DL380 G4 Server Logo
87 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
