Question about Franke 34" Undermount Double Bowl Stainless Steel Sink
There were no instructions to install my undermount sink. What can I do?
  • 2,100 Answers
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
Posted on May 15, 2010
HOW DO I SUPPORT MY UNDERMOUNT FRANKE SINK .THE INSTALLER FIXED THE SINK TO THE UNDERSIDE OF THE GRANITE WITH SILICONE . THE SINK HAS NOW LEAKED AND HAS DAMAGED THE CUPBOARDS .PLEASE ADVISE ,TO PREVENT IT...
How long ago was the sink installed?? It sounds like it was a faulty installation. Shouldn't the installer be responsible for fixing the problem??
How to Install an Undermount Kitchen Sink There should be retaining clips that hold the sink.
Apr 23, 2014 | Home
Can I drop-on this sink? or only undermount it? Thanks, Brooke
You are only restricted to undermounting these sinks because of there depth in relation to the siting of the tap, that's all. Remember if you place this sink on top you willhave to discreetly raise the tapbase fixing to maintain easy use of the taps
Jul 15, 2011 | Franke MHK-720-31-MB Fireclay Double Bowl...
I cant figure out how to use the clips for a Franke topmount granite sink. No instructions came with the sink. It is a formica countertop.
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
Aug 04, 2010 | Franke Home
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Some padding under my undermounted sink has come off. What is it's purpose? and should it be replaced? Is it part of the undercoat?
The padding under the sink is just a sound buffer. If the sink became loud when the watter hits it just glue the pad back on and you will be go.
It is not part of the under coat.
Mar 16, 2010 | Franke RGX-170 Regatta Triple Bowl...
My undermount sink in kitchen moves back and forth, how do I stop it
If you look underneath you will see mettle mounting brackets with screws try tighten them up.If this wont work the hole might be too big you will have to take the sink up and put silicon or hard as nails under the sink plate
Oct 22, 2009 | NRS A.H. Undermount Large and Medium...
Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
Jacuzzi undermount sink
Your sink is clearly made to be undermounted. No trim ring available. With all of the choices now available for sinks and faucets I would recommend that the jacuzzi sink be removed and that you select a new sink and faucet set to your liking. good luck.
Jan 21, 2009 | Jacuzzi Kitchen Iron Black Finish...
9 month old sink cracked, need to install new undercounter Kohler with clips. How hard is installation?
Not difficult. You can make it even easier by purchasing the undermount sink installation kit from Kohler. Good luck
Jan 11, 2009 | Kohler Caxton Undercounter Lavatory Sink...
Franke 34" Undermount Double Bowl Stainless Steel Sink Logo
189 people viewed this question
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
