Question about Electrical Supplies
I have a UST GG5500 portable generator and it will not produce electricity. The engine starts fine but it doesnt generate any power.
  • 905 Answers
Check your circuit breakers to see if they are tripped or damaged. Then take a look in the end of alternator / generator at the field windings. Check for damage to the brushes, as well as the diode for continuity in 1 direction only. Look for damaged capacitor regulator. Replace as needed.
Posted on Jun 12, 2010
Does a UST 5500w generator has a AVR. And if yes where is it located? Thanks for the help.
The contact number for parts and service is 1-866-797-2738.
The manual with parts is here: http://www.searspartsdirect.com/partsdirect/user-manuals/GG5500-UST-GENERATOR-manual
And it does not look like it has an AVR
Oct 07, 2016 | Electrical Supplies
What can make diesel engine to vibrate surdenly when the engine is running on load from a air compressor
When the compressor starts, initially there is a very large current draw by the compressor motor. Depending on the size of the generator and compressor motor, this could cause the generator to stumble for a few seconds, but this should smooth out within 3-5 seconds.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Cant start my ust 2300w generator
If there is a spark at the plugs ignition is fine, spraying starter in the intake should allow it to at least fire?? even if you had a carb / fuel issue. I would recommend a compression test and better still a leakdown test to determine if you have weak compression
Nov 19, 2013 | UST GG2300 Portable Gas Powered Generator
UST GAS GENENTOR TG3000 WE DO NOT GET ELEC FROM THIS WE REPLACED FUSE AND STILL NOTHING SEEMS LIKE IT RUNNING GOOD WHAT CAN BE THE PROB
If it has been sitting for a while the electrical field may need to be flashed. Check falshing a generator and follow the directions. This should excite the generator and start generating again.
Aug 26, 2011 | UST GG2300 Portable Gas Powered Generator
Please tell me How to change my oil in my ust gg 2300 generator
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing...
Aug 17, 2011 | UST GG2300 Portable Gas Powered Generator
The engine runs fine and the generator produces electricity but shortly after start up the generator head gets hot and starts to smoke. What could be the problem or solution? thanks jeff Joyce
If you really mean the "generator head", which I understand as the outer bearing cover of the generator, your problem may be a bad contact or worn out brush-ring assembly, or a bearing problem (not very much believable).
Jul 02, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Ust gg5500 dc power
trace your DC outlets backwards...they go to a certain (device)like object...test the wires goint to that device for voltage..if there was voltage then that device is burnt...you can take it to a parts selling shop and buy a new one.
Jun 22, 2009 | Coleman Powermate Powermate 5000W...
UST GG5500 generator no A/C output when I first start
Plug something into the outlet and have the breaker on when you start the generator. If it has an automatic idle control, turn that on too. A load will energise the generator.
May 02, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Electrical Supplies Logo
616 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
