Question about Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH4000AWW WHINNING SOUND ON SPIN CYCLE AND ITS BALANCE AND IT GETS LOUDER AT TIMES
  • 6,784 Answers
Dose it sound like a helicopter or an over driven electric motor?
Posted on May 15, 2010
  • Michael Masters
    Michael Masters May 15, 2010
    In some cases, motor whining is normal, but if it is unbearably loud, this will be the result of the user over exceeding the units load capacity. This will, essentially, destroy the motor windings overtime, thus, inducing the whining sound during the spin out. over exceeding the load limit of your unit will destroy the integrity of the spin pulley, as well(this will make the whining noise if damaged). Now, if it is sounding like a helicopter, this will be the result of a failed leveling system(internal leveling assembly), or weak floor station.
    Try to run a load with a simple capacity level of half a load. possibly just sheets. if this whining occurs on a light load(well under the capacity level), this will confirm that the spin pulley is worn. If the unit dose not make the whining noise while running the reduced load, this will confirm that the unit has been overloaded, thus causing the sounds of whining during the overloaded cycles.
    To remedy the overload issue, simply limit the content to the available capacity mark set by the manufacture.
Maytag MAH4000AWW no longer does the high speed spin cycle. Other than that motor runs fine. Seems like a controller issue but don't have a repair manual to know for sure.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MAH4000AWW/3048/0153200/M0603006/00013?blt=06&prst=0&shdMod=MAH4000AWW
It could be the motor control board not telling the motor to switch to its highest speed, but it could also be control board not telling the motor control board to activate, but it could also be in the timing circuit. What other indications are you getting? Take a look at the wiring diagrams for this machine on the referenced site.
Jul 01, 2011 | Maytag Washing Machines
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2011 | Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag model LAT9605AAE serial # 13662937QD washer gets out of balance constantly on every spin cycle
make sure all of the legs are adjusted correctly. maytag washers also have to be on a very stable floor. if the floor is not stable or if the legs are not adjusted properly then the machine will shake all over as if they are out of balance.
Jul 01, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
190 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
